hydraulic pumps - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
hydraulic pumps
Old 05-15-2013, 07:23 PM
Wes(MI) Wes(MI) is offline
Wes(MI) is starting off with a positive reputation.
hydraulic pumps
What size/style of crank driven hydraulic pumps did they use on these trucks? I'm in the process of converting a PTO winch to hydraulic operation. It's going on a '79 F700 w/370 bb. Thanks.
Old 05-16-2013, 12:32 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Wouldn't you want to run the winch pump off the PTO?
If you have a crank-driven pump, it would be turning all the time.
Old 05-16-2013, 11:39 AM
Not necessarily. If I decide to add other hydraulic options to it layer, a PTO pump could be a hindrance. Take a snow plow for example. You don't always drive at 2k rpm or less.
Old 05-18-2013, 12:27 AM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
Quote:
There is pretty much no standard here. It is whatever the particular aftermarket company came up with.
Two choices of pump mounting, directly on the engine or in front of the engine driven by a short driveshaft.
Ford might have, or had at one time a accessory pulley* kit which could be adapted to a engine mounted style pump, the front mounted w/shaft would be up to the final modifier. Yes, there are systems that modify the radiator and run the shaft thru the core to the pump.
* one thought would be if you had a air compressor or not. If not, then you could probably get the mount and pulley kit for that and adapt it over for a mount and v belt drive for a engine mounted pump. Use a 12v clutch, and you can engage and disengage the hydraulics as needed.
David
Old 05-18-2013, 04:31 AM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
I have quite a few mounted up on the engine driven buy belt and a electric clutch.
This was mainly on auto trans tow truck in the 90s'
Old 05-18-2013, 08:04 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.HOTWRENCH is gaining momentum as a positive member of FTE.
HYDRAULIC PUMPS
There are many choices on setting up a remote hydraulic system, PTO off of the transmission, belt driven from the engine , crank driven from the engine. All these are easy to set up , but some are quite costly. The easiest is probably the belt driven clutch pump, this gives you hyd power at the flip of a switch, this is what we use for wreckers, dumps , and snow plow setups. PTO trans driven pumps are more expensive and most can't be used while vehicle is in motion, we use these on larger dumps and wreckers ect. Crank driven pumps are mainly used on state snow plow trucks , utility line trucks with cranes or man lifts , also very expensive. There is a device that can be wired in to the hyd clutch pump curcut that won't let you engage the pump above a set rpm.
I Hope This Helps --- Hotwrench
Old 05-18-2013, 09:30 AM
FYI - There are PTO drives that can be used while driving. The Allison automatic in my dump truck supports this.
David
Old 05-18-2013, 10:00 AM
PTO'S
I said most not all-- I am very familiar with all types of PTO'S and hydralic pump drives as I have serviced and installed them for many years.
Have A Good Day ------ Hotwrench
Old 05-18-2013, 12:04 PM
Opps, sorry I missed the most. I bad
David
Old 05-19-2013, 06:40 PM
I've given thought to the belt style pump, but there's always the *potential* for belt slippage under heavy use. That's why I was thinking crank mount. Anyone have any pump part numbers or flow rates for one?
Old 05-20-2013, 08:21 AM
Talking HYDRAULIC PUMPS
Check out www.surpluscenter.com they have about anything you could want in the hydraulic line and the prices are'nt bad. As far as belt slippage on clutch pumps it's no worse than any other belt drive unit. Most clutch pumps use two belts and are mainly trouble free. Finding the adapter for the crank on a crank driven pump may be a problem. Some have to be custom built .
Have A Great Day ------ Hotwrench
Old 06-13-2013, 10:56 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
MY OPINION IS BELT DRIVEN IS THE BEST , EASIEST WAY AND MOST RELIABLE FOR ALL AROUND USAGE !
DUMP BOXES WORK GOOD FROM A PTO !
BIGGER TRUCKS IS WHERE I HAVE SEEN THE FRONT CRANK MOUNTED PUMPS MOSTLY ON CEMENT TRUCKS !
56 Ford F-600 Dump - Hydraulic Pump Bucsfan552 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-19-2012 09:19 PM
Hydraulic pump question lxlmariuslxl 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-10-2011 01:35 PM
Snow Plow and Auxiliary Hydraulics BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 05-17-2010 04:48 AM
Power steering hose problem regidog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 02-21-2010 09:49 PM
Leaking seal on PTO hydraulic pump mchild 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-04-2003 06:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
