misfire on an 02 5.4 sd - Ford Truck Enthusiasts Forums
Old 05-15-2013, 05:56 PM
prestroker93 prestroker93 is offline
prestroker93 is starting off with a positive reputation.
I have a 2002 f250 sd it misfires when it warms up at low rpm but it doesn't throw any codes does anyone have any ideas
Old 05-19-2013, 11:15 PM
rmbrown's Avatar
rmbrown rmbrown is offline
rmbrown is gaining momentum as a positive member of FTE.rmbrown is gaining momentum as a positive member of FTE.
I just had a misfire with my 01 f250 5.4 the issue was #6 coil replaced myself try unplugging your coils one by one if it idles down its good but if you don't hear a change then its bad
Old 05-20-2013, 08:55 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
If you connect a good or decent code reader you'll maybe find a pending misfire code. If that's not an option the process of disconnecting them one at a time works too.
FWIW I installed a full set of Granatelli's COP's that hate the cold---anything below 38* F over night and I'll get one or more misfire codes, the attendant rough idle too. Once the engine is up to operating temp shutting it off for just a few seconds then right back up and rough idle is gone, CEL remains unless I cancel it--which I don't do until spring or summer.
Hope this helps.
Old 05-25-2013, 03:18 AM
hood's Avatar
hood hood is offline
hood is starting off with a positive reputation.
if you smell any antifreeze with your misfire...check the spark plug hole of the COP that you replace. If you see antifreeze in the plug hole you have another problem.
-your intake manifold like mine is leaking from the coolant crossover tube where the thermostat bolts into.
-or your heater hoses could be leaking.
I had coolant leaking in #6 and #7 plug holes. I have a new intake manifold now, I hope you don't have this problem.
99 SD 6.8 losing power DetailerDave 1999 to 2016 Super Duty 5 07-07-2016 04:34 PM
Misfire babe69vw 2004 - 2008 F150 6 06-21-2015 09:59 AM
2004 F250 V8 Gas misfire Santa 1 Modular V8 (4.6L, 5.4L) 12 01-10-2014 11:55 AM
99 F250 SD showing code P0300 TommyR Modular V10 (6.8l) 3 03-10-2010 08:53 PM
2002 V10 random misfire - pending code P0720 OSS jade97 1999 to 2016 Super Duty 11 02-23-2010 08:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
