Dpfe sensor question newbie help - Ford Truck Enthusiasts Forums
Old 05-15-2013, 02:15 PM
danwelsh danwelsh is offline
danwelsh is starting off with a positive reputation.
Hi guys. New here and looking for advice/help. I have the code (P0405. Exhaust gas. Recirculation sensor a. Circuit low) I did some tests on my dpfe sensor going by this thread http://www.ford-trucks.com/forums/34...fe-sensor.html and I get 1.03 volts on the top wire with KOEO and 5 volts on the bottom wire...when i applied suction with a hose attached to the forward most hole and it changed and went up to about 2.08 no matter how hard i sucked on the hose....two things i noticed are that the suction did not hold my tongue(with or without the back hose connected.) and the back post for the hose seems half the length of the forward one and the hose came off extremely easy...the ID of the hose looks the same as the other one....also, i sprayed for vacuum leaks and found none and I took the top hose off of my egr and applied vacuum and the the engine idle lowered some but not to the point of dieing. So....is my dpfe bad? and should have the egr totally made the truck stall?
Old 05-15-2013, 06:22 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
What are you working on?
Old 05-15-2013, 09:20 PM
Quote:
Its a 2003 4.8l triton f150
Old 05-15-2013, 09:33 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Mind if I tell you the 405 code tells you the 'circuit' is high.
That's an electrical fault the PCM has detected.
This means the system operation can't be tested for performance because the sensor does not work to report the test results.
Testing the sensor won't tell you much bad or good.
If the feed voltage is good, it's either the connector or the sensor is faulty or the signal lead back to the PCM is in fault.
Once you replace it and clear the code, it may take two drive cycles to complete the PCM test, to see if the fault is cleared.
Normally the short hoses are two different ID..
Good luck.
Old 05-15-2013, 09:37 PM
So basically my dpfe sensor is bad correct?......as im getting 5 volts on the supply voltage of the connector
Old 05-15-2013, 10:13 PM
The sensor needs the 5 volts to power the DPFE electronics.
The electronics are set up to measure pressure difference between the intake ports and report that level signal back to the PCM where it's compared to a table.
The code failure is the sensor not powering properly so the ability to read pressure difference can't be made.
The PCM monitors the DPFE circuit for current flow to test the sensor and harness.
Beyond this the PCM goes through a series of EGR system performance test requests separately, to determine the system operation.
So both bases are covered.
I'm bringing you the fine points of operation so you better see what it's all about.
It likely is the DPFE. Get one or borrow one to try.
Testing it is hardly ever is very accurate.
It's a lot like telling time from one clock or two clocks. One clock you have one answer right or wrong. With two clocks saying a different time, you still don't know which one is correct if either one is or not.
Good luck.
Old 05-15-2013, 10:18 PM
Okay thanks....thats what i will do
Old 05-19-2013, 07:50 AM
Aftrmidnite Aftrmidnite is offline
Aftrmidnite is gaining momentum as a positive member of FTE.
I replaced the DPFE Sensor on my 2001 4.6 back in 2011. It was $50 and some change from the dealer. Be very careful with the silicon hoses, as I couldn't find them anywhere, other than on a large spools. I cleaned the tubes going down to the exhaust pipe with springs and wire, followed by compressed air.
0401 code bobbydee 1997 - 2003 F150 0 10-21-2016 02:39 PM
5.4 stumble, bad egr or DPFE? jprix 1997-2006 Expedition & Navigator 17 12-03-2015 07:18 PM
How to test your DPFE sensor. Reuel Modular V8 (4.6L, 5.4L) 47 06-24-2015 09:37 PM
1995 California 5.8 PCM DPFE SteelHorse4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 05-30-2014 01:10 PM
p1406 troubleshooting help marklar65 1997 - 2003 F150 0 02-13-2010 05:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
