' 85 5.0 F.I. Fuel Filter Location? - Ford Truck Enthusiasts Forums
Old 05-15-2013, 02:57 PM
tempest411's Avatar
tempest411 tempest411 is offline
tempest411 is gaining momentum as a positive member of FTE.tempest411 is gaining momentum as a positive member of FTE.
Hello,
I've found what I understand to be a cartridge filter used on the return leg of the system, but according to the parts books I should have a very familiar can type filter (Fram G3802) on the pressurized side. I'm not finding that...Stranger yet, it really looked as if the output of the pump on the frame goes strait to the rail/injectors. I've never heard of a fuel system that didn't have a filter right before the carburetor or injectors.
Old 05-15-2013, 04:06 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's what it's supposed to look like. There is a filter going up the frame rail, and there is also a small filter in the fuel reservoir which I call the switching valve.
http://repairguide.autozone.com/znet...528004ba28.gif
Old 05-16-2013, 02:36 PM
tempest411's Avatar
Thank you for posting that drawing. I am missing the filter between the pump and the injectors according to that drawing...that is very odd to the least. I'll have to do some disassembly to figure out what's going on. How brittle can I expect the factory plastic lines to be? If it's the same stuff they use on vacuum lines, I should be prepared to change out all that stuff!
Old 05-16-2013, 04:08 PM
Franklin2's Avatar
The nylon lines seem to hold up well. But if something happens, you can usually use a heat gun and slide them over a regular hose barb. If the whole line was shot I think I would switch over to metal using the universal lines they have on the rack in the store.
Fuel Filters - change at 10,000 or 20,000 miles? percyad 6.4L Power Stroke Diesel 12 02-18-2010 07:39 PM
I need HELP cleaning my fuel system!!! mongo75 1999 - 2003 7.3L Power Stroke Diesel 15 04-20-2008 06:51 PM
Rough Idle 2danglong 1999 - 2003 7.3L Power Stroke Diesel 6 04-15-2008 01:37 AM
Need help identifying fuel return line kola Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-19-2007 12:34 AM
Fuel injector filter replacement question mauicruza Fuel Injection, Carburetion & Fuel System 0 12-20-2005 04:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
