6.9l water separator conversion?
Hello,
I have a 1985 F250 with 6.9l. Truck runs great, but I recently had to totally bypass the factory stanadyne water separator due to massive air leaks.
Is there a conversion kit out there where I can add a more modern separator?
Or, better yet, can I replace the 6.9l fuel filter head with a 7.3L, which would allow the use of a spin on fuel filter/water separator? (someone told me this could be done..but, I need some expert verfication).
NAPA has a filter and head you can mount where your filter is now, with a little modification. And a 7.3 filter housing will also go in there also. Here's a link for you. https://www.ford-trucks.com/forums/1...l#post10152121
Thanks for the information guys. I think I will try the 7.3 header, although the NAPA kit looks great too. I am in the Dallas area and plenty of junked 7.3l's in the junk yards around here.
Just fyi on the water separator; yes, I had the drain hose plugged with a valve and that was ok for a while, but it became so hard to start and I eliminated every other possibility, I finally just disconnected the 28 yr old separator and rerouted for staight fuel and it fired RIGHT UP no problems, runs perfect. So, apparently, there was another area on that separator that was allowing air in to the lines that I could not visually observe.
Thank you again....Go Ford!
i'd skip the 7.3 head and go with the napa head and filter at the very least. My filter head used to be nice and dry.....well now it seeps fuel from just about every possible spot......99% ready to delete it and do a frame mounted dual filter set-up. that will give me a water sep/pre-filter, like the napa filter that is in the link, and then a secondary fuel filter. No leaks, more/better filtration, and will clean up the engine bay a touch(mine is a little crowded lol)
That is interesting. I also saw a replacement kit setup from Baldwin Filters that the Dieselmann has on his site. I appears to be set up to totally replace the factory Stanadyne right there on the fire wall in the same spot...maybe have to get a spacer....but, that looks like a real nice option. $95 on the website.
yep, sorry about that...here is the link...go about 1/2 to 2/3 down the page.
dieselmann's Store: Filters
i'm looking at this for the water sep....Wix 33367 & Napa 3367 Fuel Filter: FleetFilter Secure Online Store
secondary filter...Wix 33528 & Napa 3528 Fuel Filter: FleetFilter Secure Online Store
then two of these heads....Wix 24770 & Napa 4770 Base: FleetFilter Secure Online Store
