brake conversion on a 57 f100 - Ford Truck Enthusiasts Forums
Old 05-15-2013, 08:43 AM
rgoodell rgoodell is offline
rgoodell is starting off with a positive reputation.
disc brake conversion using 5 on 5.5 rotors, what do I need ?
Old 05-15-2013, 12:25 PM
a4t1rat's Avatar
a4t1rat a4t1rat is offline
a4t1rat is starting off with a positive reputation.
Rotors
Calipers
Caliper Mounts
Bearings, Races and Seals
Master Cylinder
Proportioning Valve
Brakes Lines
Brake hoses
Search the forms there is a good write up on here, just forget where. Pretty easy I have done many of them.
Old 05-16-2013, 06:46 PM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
I got my kit from ECI.
Old 05-17-2013, 04:50 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Quote:
How well did everything bolt up? Any problems? I'm considering their stuff down the line
Old 05-17-2013, 07:53 PM
Walston's Avatar
They worked very well and bolted up easy. Some pictures in my gallery. Here is one.
http://www.ford-trucks.com/user_gall...=73494&width=0
Old 05-17-2013, 07:58 PM
vntgtrk's Avatar
Clean look, almost like a factory install. OP, most of these kits you'll see on the interwebz are available either complete or stripped down. With the stripped down kits you use salvage yard ford truck rotors/hubs and GM big car calipers from, IIRC, late '70's to early '80's. I plan on running drums to start, but I have a pair of the proper rotors. They've been turned already
Old 05-17-2013, 08:22 PM
Walston's Avatar
It has been a few years, but if I remember correctly you remove all the old stuff and reverse the pin that holds the king pin in place. I replaced the kin pins at the same time. Bolt the bracket on. That is the most important part. The calipers and are late 70's GM, the rotor are late off an f150. You have to change the bearing race and the bearing to fit the old spindles. Need a hydraulic hose, need a new master cylinder, I use one from a 1973 F100 that had disc and drum. It was cheap and didn't need a proportioning valve. I also used the booster and mounting bracket from the 73. The kit is easier, but after the bracket, the rest can come from a salvage yard.
Old 05-17-2013, 10:30 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
Be sure to read this "How-To." Had I read it before I did mine, it would have been 1000x easier! Good photos, too.
Installation of Manual or Power Brakes Disc Brakes in a 1957 - 1964 F100 .: Articles
Rear disk conversion seancaros 1973 - 1979 F-100 & Larger F-Series Trucks 45 08-08-2016 10:38 AM
Disk brake conversion Robert Moore 1957 - 1960 F100 & Larger F-Series Trucks 5 07-02-2015 09:11 AM
Brake Drum to Disc conversion kits? 93XLTowner Brakes, Steering, Suspension, Tires, & Wheels 8 04-30-2012 03:55 PM
E 350 Conversion Van 1986 Towing Capacity? aviatorthree Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 5 03-11-2005 12:24 AM
Towing Capacity 1986 E 350 Conversion VAn aviatorthree Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 1 03-07-2005 12:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
