Eats starters
I wish I could think of the name of the function, but the starter both spins the gear, and pushes the gear out to turn the motor over. It sounds to me like the gear isn't retracting, which could be a solenoid issue. Solenoids are cheap and if yours has never been replaced, you should probably replace it anyway so if that doesn't fix it, at least it was preventative maintenance.
If it's eating starters, I'd think either the solenoid is remaining powered, he's just had a bunch of starters with stuck solenoids, or the parts store is giving him the wrong starter and it's staying engaged with the ring gear even after being de-energized.
Take it out and bench test it. See if the starter gear is retracting fully. What shape is the ring gear in?
I changed the transmission an transfercase out of the same year half ton, then it started doin it. It never did it b4 but the truck was jackknifed with a fifthwheel trailer on, the deck of the trailer caved in the passenger door an im guessing busted something in the trans, when i got it it was stuck in 4th gear. I put the original starter in it then 4 other used ones outa various other trucks i have one was an auto the rest standards.
Complete new clutch assembly including flexplate and steady bearing were installed at time of trans swap, trans an t-case were all same numbers as what came out of the truck. Only thing that was different was output yoke to front drive shaft,changed that to fit the larger 3/4 ton u-joints.
A 5.8/manual wasn't offered in a F150 , what engine did the trans come from? You might be having issues w/ a non compatible bell housing and flywheel. The 5.0 engines used a 157 tooth flywheel where a 4.9 and a 5.8 uses a 164 tooth flywheel, since the bell housing is where the starter mounts it needs to be the right bell housing for a specific flywheel.
Yeah, You cannot jumper the hot lead.
Run the heavy starter cable from the battery+ side of the fender mounted solenoid and a 12Ga. wire from the switched side of the fender solenoid to the starter solenoid trigger.
Remember, an electric motor becomes a generator if it is driven.
When the ring gear starts driving the starter, it is powering itself on, and the fender solenoid will/cannot stop it.
kindashort
07-10-2010 12:10 PM
morimoto_87
02-04-2010 01:45 PM
75highboy
16
05-15-2009 11:44 PM
