Help with 292 Broken Flywheel!! - Ford Truck Enthusiasts Forums
Old 05-14-2013, 07:51 PM
500Dave 500Dave is offline
500Dave is starting off with a positive reputation.
Hi - I am new, well sort of, to this forum. Joined about a year ago. Anyway, my son and I are working on a 56 F100 that has a later 292 engine (possibly a 1959). Motor fell and cracked the flywheel. The clutch has the 10" disc. What flywheel can I use to replace it? Are there different balances, or will any flywheel from a 272 or 292 work? Any help is appreciated. dberg@nep.net
Old 05-14-2013, 08:08 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Sorry about your troubles. You may well want to post in the Y-Block V8 (239, 272, 292, 312, 317, 341, 368) section down towards the bottom of the forum list page. There may be those here who know but it can't hurt to ask others.
Old 05-14-2013, 08:10 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Flywheel specific to starter drive (11350), which type does 292 have? / I used 1964/72 CD catalog pic cuz it's easier to post than scanning pic in 1957/63 paper catalog with magic wand.
Old 05-14-2013, 09:06 PM
flywheel
thanks. definitely the inertia type starter. I know the flywheel has 146 teeth on the gear.
Old 05-14-2013, 09:24 PM
If only the ring gear cracked, it's replaceable by itself.
B4AZ-6375-A .. Flywheel-146T Ring Gear / Use with Bendix Inertia Starter Drive / Use with 10" & 11" clutches / (6) 5/16" -18 pressure plate attaching holes on 11 3/8" & 12 3/8" bolt circles.
1954/58 239/256/272 / 1957/64 292 / GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
Old 05-14-2013, 09:58 PM
Flywheel
Nope, that would be too easy. The flywheel is cracked in half and will not be fixed. pretty obvious from the side as it looks a little crescent shaped. Too much of a hurry on my part trying to get it ready for my son and now I am in deep doo doo! Thanks for your help. If anyone has one for sale . . .
Old 05-14-2013, 10:33 PM
If you buy a user, how do you know you'll get the correct flywheel since there's two different types? Only B4AZ-6375-A will work with both 10 and 11 inch clutches.
T'other (B4AZ-6375-B) only used with 11" clutch. And, most ebay sellers haven't a single clue what parts fit, even if they're NOS with part numbers marked on them.
Take a look-see at post 5 again, found one NOS
Old 05-14-2013, 11:43 PM
Flywheel
Thanks. I did not know that. I will check them out in the AM. Again - thanks so much for the help.
Dave
57 Ranchero Carl 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-02-2016 07:29 AM
64 292 Manual Trans - Correct Harm Balancer 1964FORDTUF Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 10-11-2014 08:37 PM
flywheel torque # Deadeye1963 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 03-03-2009 10:16 PM
clutch and flywheel problems reecem13 Clutch, Transmission, Differential, Axle & Transfer Case 0 08-03-2008 09:51 PM
Need Flywheel Replacement Help on 4R70W Tranny OE812 Clutch, Transmission, Differential, Axle & Transfer Case 1 08-02-2004 07:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
