I need major help, brake, clutch pedals
Old 06-07-2003, 05:40 PM
joners's Avatar
joners
joners is offline
Hey there guys, I have a 1954 F-100. I was dumb and tossed out most of brake/clutch parts. I found the clutch pedal and the long rod that it swings on. I was planning on getting a new brake booster anyways because the old one was shot and leaky. Can anyone take pics of their trucks, of the pedal assembly on the underside of the truck? Thanks
Steve
Old 06-08-2003, 06:41 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Steve,
I'd like to sell the complete pedal assembly out of my 48 if you are interested. I'm going with a hanging pedal. I'm not sure if it's the same as your 54 or not though. If you are interested drop me an email (New_Hampshire_Yankee@Yahoo.com).
Old 06-08-2003, 10:38 AM
joners's Avatar
joners
joners is offline
email sent!
Old 06-08-2003, 10:59 AM
51dueller's Avatar
51dueller
51dueller is offline
Note: The F-3 pedal assembly WILL NOT fit a F-1. The parts will interchange but the bolt holes are farther apart.
Old 06-08-2003, 12:03 PM
Purple55's Avatar
Purple55
Purple55 is offline
I assume that you're sticking with a manual trans.
But if you're not,I went with an auto and I'm using the clutch pedal on the left side of my steering column as the brake pedal with a frame mounted booster.
I can get pics if you or anyone is interested.
Old 06-08-2003, 11:29 PM
joners's Avatar
joners
joners is offline
yes, get me some pics PLEASE!
As for bolt holes, the frame is boxed now, so i'll have to do some changing of the brackets and such. and yes, im staying with manual tranny, from a 90 mustang.
Old 06-09-2003, 12:51 AM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Fat Fendered Ford is offline
I have some pictures I took when I disassembled my pedal pivot assembly. Do you have a fast connection? I have about ten pictures (800k each) that should be helpful. Let me know.
Old 06-09-2003, 06:57 AM
Earl's Avatar
Earl
Earl is offline
Hi Steve,
Once you get the pics from Kevin, the illustrations below might help with some of the details. Good luck.
Old 06-09-2003, 07:45 AM
joners's Avatar
joners
joners is offline
So the linkage to the clutch fork, is a rod? LOL
When the truck had the Flathead with 3spd, the guy had rigged up a wire setup...I wondered why it looked sorta half assed. Also what is a good kit to get because I'm using a disc brakes on the front drums on the back? I don't beleive the stock brake booster will do the job.
Fat Fendered Ford, yes I do.
Thanks for the other pics!
Old 06-09-2003, 09:04 AM
ddurant's Avatar
ddurant
ddurant is offline
steve
i just finished putting a power disk kit on my 49. it wes easy to do it just bolts up. the bearing adapter is no fun to get on. the kit even includes new bearings.
heres the link
http://www.classicperform.com/
Old 06-09-2003, 05:20 PM
joners's Avatar
joners
joners is offline
hmmm, looks like a nice kit. thanks for this site as well!
Old 06-09-2003, 07:32 PM
Purple55's Avatar
Purple55
Purple55 is offline
Steve,
I added a couple of pics of my "clutch pedal turned brake pedal" to my gallery.
Old 06-09-2003, 11:24 PM
joners's Avatar
joners
joners is offline
thank u sir!
Old 06-10-2003, 10:19 AM
Fat Fendered Ford
I updated my web site with more pictures of the pedal shaft disassembly process. For some reason, the url gets mangled when I try to post a hyperlink in my message.
You'll have to follow the link below to my web site and use the link on my home page.
Enjoy!
Old 06-10-2003, 01:13 PM
Earl's Avatar
Earl
Earl is offline
Hey Kevin,
I just wanted to see if the URL gets mangled when I try to post it using the newfangled http:// button. Let's see if this works. Give it a try and if you get the right page, I'll try to remember how I did it.
Kevin's Archives
Quick Reply: I need major help, brake, clutch pedals
