FM-146 1991 Ranger Transmission output seal replace?
I'm pretty certain the output seal on my FM-146 is shot as I have a nice little gear oil spot on the driveway each time I park the truck. I don't recall what it looks like inside the output end of the trans. What is involved with replacing the output seal on a trans with transfer case? I seem to recall the output shaft hangs out some distance past the seal and you cannot pry the seal out like a 2wd. Is this a job for a slide hammer? I tried searching the forums but no exact hits with pictures to my question.
Thanks,
Thanks,
I don't know about replacing the rear seal but maybe a member that does will post up. On these transmissions the rubber shift rail plugs dry rotting, leaking & blowing lube back to drip off the tranny tail shaft are a common problem. So with the vintage of this tranny, be sure to put the rubber shift rail plugs on your suspect list & check them, before replacing the rear seal!!!! More thoughts for consideration, let us know what you find & how it goes if you have to replace the seal.
Incorrect
Now, has anyone replaced the output 4x4 seal with the trans in the truck?
Park the Ranger. Drive the Fairlane. It only has to pass a gas station or two before you need to fill up...
Most transfer cases have a splined u-joint carrier that is held to the output shaft by a large nut. Remove the driveshaft, look in the center and you should see the nut. Remove the nut, and the carrier will {should} slide off the spline. Then you can use a puller, or slide hammer & self-tapping screw to remove the old seal.
If yours is not like that, I have no idea. On automatics, we could replace the tailshaft seal in most cases without removing the tailshaft. We even replaced bushing, driving the old one onto the output shaft {it didn't mind riding around there} and installing in a new one.
tom
tom
tom
tom
had the Fairlane out for a little strip time 2 weeks ago!
cmlind
04-27-2005 07:31 AM
