Electric Gearmotor Lubrication Question.
on
We have a gearmotor sitting here we'd like to rebuild and get running again. All it needs is a new pinion seal which we have, along with the gasket that fits between the gear housing and motor.
Here is the gearmotor: DAYTON Gearmotor, AC, 14 RPM - Gearmotors - 6K325|6K325 - Grainger Industrial Supply
The application is a chain drive assembly in a coffee roaster that turns both the roasting drum and a rotating arm in the cooling chamber - not a lot of load, but a great deal of heat (upwards to around 450-500 degrees.)
When we split the case, we're going to lose the oil - we can try to contain what's left and reclaim it, but some has already been lost. All I can find in the specs is that it uses a "Permanent Heavy Duty Gear Oil" but doesn't go into specifics. It has a filler plug so, that implies it was meant to be filled/re-filled.
For those who might know, what would work as a suitable replacement gear lube for this unit?
Thanks in advance.
Thanks in advance.
You might try using a motor and gear box rated for hostile environments next time too.
on
This gearbox was the original that the roaster was built with - it had been replaced some time ago after the pinion seal got screwed up and we wanted to rebuild it just to have one around as a backup.
The roaster is similar to this one: Diedrich Manufacturing, Inc. - Diedrich Coffee Roasters - Coffee Roasting Equipment - it's an older model IR-12 so, there are some cosmetic differences (it's all black, for example) and it doesn't have that fancy control screen...
Thanks again.
Thanks again.
preppypyro
05-20-2008 10:18 PM
