2000 5.4 excursion oil problem - Ford Truck Enthusiasts Forums
Old 05-13-2013, 01:43 PM
borwish borwish is offline
borwish is starting off with a positive reputation.
A good while ago my father bought a 2000 excursion 5.4. He mainly got it to haul stuff around, so he doesn't drive it often. He was driving it a few days ago when the check engine light briefly came on and went back off before he got to work. I happened by a few hours later and looked around and saw that the oil level was a few inches higher than the max mark on the dipstick. I couldn't detect any water or gas in the oil and the coolant and transmission levels were fine. I took it a few miles away to my house to change the oil.
I did a normal oil change and added 6 quarts of oil with a new filter. When I transfered the old oil to a jug for recycling only about 2.75 quarts were in the pan. I checked the oil level again and it shows a few inches too high still. I drove it about two miles to circulate the oil and it was still high and looked dirtier than it should. What issue am I looking at here?
It was 5000 miles since the last oil change and it might have had only 5 quarts added at that time. Dipstick number F81E-6750-JA
Any and all advice is welcomed,
Thanks in advance,
John
6.7L Oil Change concerns JustinRo2014F250 6.7L Power Stroke Diesel 15 04-02-2014 08:47 PM
2000 Excursion V10 I ran oil low BroncoRN Excursion - King of SUVs 10 10-17-2013 07:59 PM
Oil Question… bigdaddyII 2009 - 2014 F150 4 08-07-2013 06:24 PM
Cooling Problem - Long Post cay5628 6.0L Power Stroke Diesel 14 06-14-2013 11:03 PM
2000 5.4 excursion oil problem borwish Excursion - King of SUVs 7 05-13-2013 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
