Explorer brakes on an Aerostar, project notes.
One of the weak areas in my Aeros has always been warping the rotors. I can't count the number of times I've had to have mine machined or replaced. My current AWD is starting to exhibit the symptom again, and I'm ready to spring for better rotors as well this time.
I never need to replace brakes, I'm very easy on them, but the rotors! Arrrgh!
Rojo, don't weld the sleeve to the knuckle. That piece gets special treatment.
Diversified Cryogenics & Applied Rotor Technology in California provides the same product- but I would not rely on ART IMHO- it is essentially a 1 person shop owned/run by a Boeing engineer who works back east, travels alot and works at ART on weekends the last of my phone conversations with him).
I always torque lug nuts. I've done it often enough on my Aeros, what with seasonal wheel changes for snow tires, that I've got the spec memorized: 95-100 ft/lbs.
I'm very easy on brakes, always gear down on downgrades . . . I don't know why I have so much trouble with warped rotors, but I sure do!
explorer brake conversion
I was actually curious if newer ranger/explorer knuckles would work instead of all the fabrication since the knuckles are designed for 15-16 inch wheels and since people don't have access to jy's or all the tools to fabricate that way we can save down time with our aeros as well as have better brakes. Please let me know so i can perform this task, have better brakes and save down time since this is our only vehicle and our rotors are warped as well, and i even tighten my wheels in 20 pound increments. Please help
I count the front brake retrofit as one of my overwhelming success stories.
It hauls the vehicle down with authority and absolutely no faults so far.
The Explorer rear discs are yet to be installed, but all ready attached to the Exp 8.8 rear axle hanging on my wall.
As for alternate knuckles/spindles, I actually brought in both the Explorer and the Ranger but neither were even close. Definitely not drop ins or even a starting point for mods. I hear what you're say'in about equipment and skills, so you might try approaching some kind of fabrication shop with a spare set acquired thru mail-order. Fortunately everything is documented on this thread.
Well, almost everything.
Here is the tracing of the bracket that gets welded in, on millimeter paper.
Since it is a tracing, the outline shown is a pencil point outside the actual perimeter.
Years after producing the tracing, I do not recall the meaning of the datum, but its likely the nominal location of the bolt hole seen in the pic below.
Other unrecollected scribbles on the same paper...
- "Caliper Bolt, Upper 3.665R from Spindle" (probably meaning axle center line)
- "Caliper Bolts, c-c 5.675"
I suspect these two notes triangulate the location of the second hole, once the first hole is set (at say 3.665R from the axle).
Done it
I know this is a very old thread, but I just registered to be able to post a reply. Thanks for the very informative, actually inspirational article. I just finished doing this upgrade about three weeks ago and I couldn't be happier with the results. I have solid stopping power and I think the larger rotors will not have to be replaced because of warping for a long time.
Looked at this as I had an 94 Aerostar. The thing I did to increase Brake Performance was Swap the Brake Hoses out to Russel Stainless Steel Braided DOT Hoses. To make it easier to install the Sleeve on the Spindle, try this. Put the Spindle in the Freezer, Heat the Sleeve up in a 400 450 degree oven. We used this trick for replacing Bearings on Electric Motors. Also for Removing Aluminum Axis Fans from Steel Shafts. We used CO2 to freeze the shaft. Propane to Air Torches to heat the fan hub.
You can find another of my rogue brake projects over in the BMW world where I am Hyper.
Over there, guerilla machining, CAD yahoo'ing.
ZooDad
6.7L Power Stroke Diesel
161
07-27-2022 08:38 PM
BrizNasty
32
12-13-2021 09:40 AM
WVVan
05-27-2015 03:53 AM
sammie0126
08-20-2014 06:06 PM
