2007 Expedition battery being drained - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-13-2013, 08:06 AM
jlppimb jlppimb is offline
jlppimb is starting off with a positive reputation.
I have a '07 Expedition with a battery drain. Hooked a meter up to it and after a couple mins the meter will show the truck is in "sleep" mode with a low mA reading. About every 30 secs the meter will jump to between 7-9 Amps for about 3-5 secs then back down to a low mA reading. Cant remember the actual low number, even reading 0. Even before the truck enters "sleep" mode the same cycle is going on, just the mA aren't as low of course. I'm thinking this is the smart junction box, but didn't have time to stay at my friends house using the meter to pull fuses. Also I was trying to find out what fuse number the SJB is. Any help please? Or ideas if I'm on the right track. Thanks!
Old 05-17-2013, 07:44 PM
dgruhlke dgruhlke is offline
dgruhlke is starting off with a positive reputation.
Had a battery drain on my 07, turned out to be the rear wiper motor, common problem.
Old 05-17-2013, 11:09 PM
Rear wiper motor? How did you find out thats what it was? Any idea what fuse that is? Im gonna look it up now! Thanks fo the tip I'll check that out tomorrow.
Old 05-17-2013, 11:13 PM
Fuses 19 or 43 Check those tomorrow.
Old 12-19-2014, 10:25 PM
mot250 mot250 is offline
mot250 is starting off with a positive reputation.
Fuse 19. I figured out my problem. I knew the rear wiper didn't work but the motor did, or tried to. When I would pop the rear window, the wiper motor would cycle then park. The the battery would not drain any more. Pulled fuse 19 until I could fix the rear wiper.
Fixed the rear wiper this evening. Search for rear wiper in this section for details but I basically removed the rear wiper arm, disassembled the pivot arm from the assembly, cleaned all the parts and reassembled it. Wiper works now.
Poor design allows grit to seep into the assembly and cause it to seize up.
Good luck!
Old 03-18-2015, 08:03 PM
2000F350Scott 2000F350Scott is offline
2000F350Scott is starting off with a positive reputation.
Yep, same problem here on my 2007 Expo... knew the rear wiper pivot was crudding up lately, but didn't know it tries to "home" the wiper even with the KEY OFF. Found out by the dreaded dead batt. Had greased the pivot a few years back, guess I'll plan on doing it each Spring--oh well. Thanks for the previous posts, glad I wasn't the only one. I was scared the PCM was going goofy---glad it's only the wiper thing. Thanks guys!
Old 03-18-2015, 09:02 PM
EECGeek EECGeek is offline
EECGeek is starting off with a positive reputation.
Rear wiper pivots
The rear wiper pivot is a common cause of rear wiper not working and battery drain. The high amp draw intermittently is the GEM trying to return the wiper motor to the park position, which it can't because of seized pivot, unless you happen to open the rear window and in that case the wiper motor will park.
Greg
Old 03-24-2015, 01:03 PM
Yep, pull the hole thing apart, clean out the pivot tube and the pivot shaft, re-grease it and install a new o-ring. Mine has been great for the last 4 months of Northern IL winter since I fixed it.
Old 05-19-2015, 10:14 AM
mont974x4's Avatar
mont974x4 mont974x4 is offline
mont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to behold
Our 6 disc changer won't let you load cd's and just keeps cycling. I was told that can drain the battery as well. I learned that when we first bought it and the radio would not turn on. Turns out the previous owner had just pulled the fuse. That was about 4 months ago. I put a new fuse in it when we bought it and just now had the dead battery issue pop up.
I'm going to see if I can have the radio swapped this week.
2006 f350 6.0l battery drain HillbillyJoe 6.0L Power Stroke Diesel 13 09-13-2016 12:51 AM
20012 Expedition Battery Drain csf 1997-2006 Expedition & Navigator 10 07-12-2016 03:35 PM
Battery Drain 257BEE 1997 - 2003 F150 26 04-05-2016 10:45 PM
500mA Draw Killing Alternator & Batteries work4it Excursion - King of SUVs 13 03-03-2014 09:37 AM
cant find parasitic draw kornfanjoe 6.0L Power Stroke Diesel 49 10-21-2013 07:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
