Fluffy White Stuff - Ford Truck Enthusiasts Forums
Fluffy White Stuff
Old 05-13-2013, 06:26 AM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
Fluffy White Stuff
I opened the access panel that is near the floor, just behind the driver's seat on a 65 Econoline van, and found it stuffed with fluffy white stuff... it looks a lot like blown-in attic insulation.
Is this supposed to be there?
I found the same kind of material between inner and outer rocker panels on a 1970 Cougar, and a bunch of Cougar guys said they had never seen it before, and it must be the work of rodents.
Seeing it in a similar place on a different vehicle makes me think maybe it's supposed to be there.
It looks like it would trap moisture and promote rust. Is it just sound deadening material?
Old 05-14-2013, 01:27 AM
Zigmyster Zigmyster is offline
Zigmyster is starting off with a positive reputation.
I'd be betting it is the stuffing from your seat or from the padded insulation/sound deadner from above the headliner or from the front wall. Mice like to use it for bedding. It could also be from some stuffed chairs that you had in the garage and the mice moved it there to build a nest. I've had that happen to me a few times before. Somehow they managed to pull the stuffing out of a patio deck chair and build a nest in behind the shroud on my garden tractor.
Old 07-17-2013, 06:40 AM
Jippah's Avatar
Jippah Jippah is offline
Jippah is starting off with a positive reputation.
id be willing to bet that its from rodents. critters will find seat foam and other fluffy items and haul it into cramped places to make their nests.
ive seen them in some pretty interesting places; headliners being up there on the strange level.
Old 07-18-2013, 02:58 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
There should be nothing behind that access panel.
7265 LawnBoy Running Rich - ? Buehler? Tedster9 General NON-Automotive Conversation 14 01-12-2017 06:22 PM
Leaking a clear fluid behind drivers side front tire that crystalizes shultzaberger Ranger & B-Series 16 04-03-2016 07:52 PM
1993 F150 speaker replacements woodsnake Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 02-11-2016 06:22 PM
WINTER & SPRING CHAT 2015 UP_There Arizona Chapter 219 06-07-2015 10:28 PM
General Chatter IV Parrsboro Washington Chapter 1466 06-09-2010 06:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
