Flywheel help 1966 289 - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 05-12-2013, 09:15 PM
Honeybadger Honeybadger is offline
Honeybadger is starting off with a positive reputation.
HI Guys - need some help. I have a 66 F100 that came to me with a 1978 351M that was shot. I pulled it out and installed a 1966 289 out of a 1966 Bronco. The 289 didn't have a flywheel so I ligned up the 351M flywheel and it bolted right in. But when I took the first drive the whole cab/engine was really vibrating severely. I had a couple of mechanic friends look at it and they said it was probably the flywheel.
I just pulled it apart today and lighned up the new flywheel which is supposed to be for a 66 289, with the 351M, and the 289 flywheel is 1/2" smaller diameter all around. I don't think the teeth will lign up with the starter but I'd have to assemble it all together to see. Also, this flywheel is "externally balanced" and came with a bolt on plate. If I install this one do I install the plate (and if so where on the flywheel?), or leave it off?
Any help would be appreciated.
C6 Auto Swap - Flywheel & Separator Plate BushyTea 1961 - 1966 F-100 & Larger F-Series Trucks 14 01-25-2015 07:14 PM
Throttle cable help - 1966 F100 Honeybadger 1961 - 1966 F-100 & Larger F-Series Trucks 11 01-05-2015 03:13 PM
Help...Flywheel/Crank Locked-up Sean_Reno 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 37 11-07-2014 09:25 AM
79 460 with a 4spd manual flywheel ?? 78_f150 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 08-29-2013 11:44 AM
1966 289 Flywheel help Honeybadger 1961 - 1966 F-100 & Larger F-Series Trucks 0 05-13-2013 07:37 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
