New Leak please take a look - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-12-2013, 09:30 PM
jonnydz jonnydz is offline
jonnydz is starting off with a positive reputation.
Check out the pics. 99 f250 4x4. I have a leak in my front axle shaft. It looks like it is coming out of the dust cap on the end of the front shaft. I am pretty sure it is differential fluid from the smell. Is there a seal before the dust cap? Is the shaft hollow with fluid in it? I thought it was just in the differential and if it leaks it is at the seals where the axle goes into the differential not at the otter end. Thanks for the help
Old 05-12-2013, 10:28 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
There is a inner seal close to the pumkin on both axle tubes. If you have fluid coming out the end then that inner seal is bad. The tubes are not suppose to have any fluid in them..
Old 05-13-2013, 09:17 AM
Pics added.
My 64 F100 64jjwf100 1961 - 1966 F-100 & Larger F-Series Trucks 9 02-07-2014 02:08 AM
just took apart my front end... what to replace jonnydz 1999 to 2016 Super Duty 2 10-11-2013 11:08 PM
help removing warn hubs jonnydz 1999 to 2016 Super Duty 5 10-07-2013 12:05 PM
check out my new military tires and a PSI question jonnydz 1999 to 2016 Super Duty 8 06-22-2013 11:21 PM
new fluid on the ground?? w/pics jonnydz 1999 to 2016 Super Duty 15 05-16-2013 07:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
