Super Charger/gauge cluster swap< HELP - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 05-12-2013, 08:28 PM
99F250LDEXTCAB's Avatar
99F250LDEXTCAB 99F250LDEXTCAB is offline
99F250LDEXTCAB is starting off with a positive reputation.
i bought a smashed lightning for parts and swaped out the supercharger to my f250 and i swaped out the cluster to use the factory boost gauge and the pats is not letting me start, can any one tell me how to either swap the pats module in the clusters or what i live over 4 hours to a city and deffinitly cant have it towed that far.
Old 05-13-2013, 04:03 AM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
you need to use the lightning ecu along with the gauge cluster for the pats to work properly. Your only other option is to get with a lightning turner and have them turn off the pats in the tune
Old 05-13-2013, 05:33 AM
ecu location
Quote:
ok then where is the ecu located in these rigs? and it will work for me then if i swap the ecu's?
Old 05-13-2013, 05:39 AM
key
also wouldnt i need to use the key from the lightning if im using the cluster and ecu?
Old 05-13-2013, 04:37 PM
Pili's Avatar
I'm not sure where exactly the ecu is. I want to say passenger side kick panel. And yes the ignition would need to be used as well. But like i said earlier when you go to get tuned just get the pats turned off.
Also while im thinking about it. a n/a 5.4 has a slightly higher compression ratio then a boosted 5.4. Its not much but i would defently make sure the tune is stop on or you will be doing the window mod.
Old 05-13-2013, 05:30 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I know you have a 250, but this is what is needed to convert a N/A F150 to run a Lightning S/C. http://www.madenterprise.com/scparts.htm
Mike has it down pat and is very helpful and I bet he wouldn't mind answering any questions you have.
Stewart
Anyone really familiar with PATS system (interesting story) thegreatgate 2004 - 2008 F150 1 07-18-2015 11:10 PM
info on how to swap from idiot lights to gauges tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-14-2015 01:08 PM
1997 F250 LD Instrument Cluster Swap For One With Tach? TrdLtly 1997 - 2003 F150 5 07-02-2014 01:35 PM
2002 excursion pats maxvolt61 Excursion - King of SUVs 3 12-12-2011 08:16 PM
95 f-150 gauge cluster swap? mikey67156 1987 - 1996 F150 & Larger F-Series Trucks 6 02-02-2002 11:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
