Does a 351 Cleveland fit well in a 56 F100 or is a 351 Windsor a better fit? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-13-2013, 07:27 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Neville,
Another alternative you may want to look at - Edelbrock Top End Kits.
Edelbrock.com - Power Package - Top End Kits - Ford
http://www.summitracing.com/parts/edl-2027/applications
$1600 (US$) buys you a kit that will produce 321hp/337 lbs torque from
your existing 302. They also have a different kit that will do 367 HP.
You don't have to go through the expense & frustrations of sticking another engine in there - just use the bottom end of the one you have.
The 302 will put out a nice amount of HP with a little love.
We went with the 351W Edelbrock Top End kit - right around 400HP in our 1950 F1.
Good luck over there.
Ben in Austin
1950 F1 (351W/AOD)
Old 05-13-2013, 08:17 PM
Aus56's Avatar
Aus56 Aus56 is offline
Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.
Ben, thanks for the info, it should ber interesting when I can study it at home. I will investigate and have a discussion with my mechanic about it. It is well worth investigating all avenues before I get too involved with it.
By the way, your truck looks great, love the colour.
Old 07-03-2013, 12:57 AM
chevys-suck's Avatar
chevys-suck chevys-suck is offline
chevys-suck is starting off with a positive reputation.
Cleveland all the way. Here in the U.S. anyways the engine mounts are the same as the 302 and should drop right in place. just get some sanderson FC3 headers for it and call it good. They come cermic coated and are a nice tight fit. BTW mail me some closed camber small port ausi. heads for my cleveland so I can get more torque and less HP out of my cleveland in my highboy 4x4.
Old 07-03-2013, 04:55 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Those heads aren't worth much here, I have 2 or 3 sets sitting on the shelf that will probably end up at the scrap yard. Everyone chasing hp goes for alloy heads, the CHI 3v heads are nice. 4v heads bring good money but aren't great for streeters.
351 Cleveland better than a 351 Windsor? FireBlue 1987 - 1996 F150 & Larger F-Series Trucks 28 02-09-2010 11:09 PM
351c Toploader bell housing on a 302?? mgoovaerts 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 10-18-2005 09:17 PM
Windsor VS Cleveland??? finnly56ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 03-01-2005 03:46 AM
Cleveland or Windsor????? Tugboat Joe Performance & General Engine Building 7 08-24-2003 03:01 PM
351 W vs 351 C vs 351 M FordRacing2 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 15 08-12-2003 10:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
