1949 F4 Flatbed - Ford Truck Enthusiasts Forums
1949 F4 Flatbed
Old 05-12-2013, 07:03 AM
awjjim's Avatar
awjjim awjjim is offline
awjjim is starting off with a positive reputation.
1949 F4 Flatbed
New to forum with new project. I have a 1949 Ford F4 flatbed with 158" wheelbase and a 12' bed. Truck assembled in, Kansas City.
The bed construction seems to be unique although I have seen one other photo that resembles it. any comments will be appreciated.
As for the rest of the truck, I have it completely disassembled, sourcing a few needed parts. It has a Flathead 226 6cyl H.
As the build progresses I will update.
Old 05-12-2013, 07:12 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Welcome to the forum. Love those F4s. Yeah, that appears to be a special purpose bed, can't figure out exactly why the lower frame work.
Edit: Perhaps the framework on the lower bed was for tie downs so as to keep a tarp tied low enough to keep water from the bed surface? Anyone?
Old 05-12-2013, 07:48 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
My welcome too. Love the big models. But must say, if you have a 158" wheelbase the truck has either been lengthened from its stock 134" wheelbase, or it's really an F-5 or F-6. F-4s all had 134" wheelbase single wall frames. You might check the VIN to confirm, or crawl under it to see if there are signs of the frame having been stretched. Also would suggest you become familiar with your "widow maker" wheels. Stu
Old 05-12-2013, 08:06 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Welcome . What are your plans for the truck .
Old 05-12-2013, 08:40 AM
awjjim's Avatar
It is an F4 with a 24" splice. It appears to have been done in the factory, very clean welds, section fits in with matching angles, reinforcing plate cut clean and angles along frame, bolts on with consistant hole pattern. Also has additional cross member at this location. there is a section added on the back also very clean in matching the frame. Frame will be back from powdercoat later this week.
I have already sourced a set of seven 19.5" wheels, these will be in the shop tomorrow.
I am restoring this truck back to how I received it including the bed. I will probably embilish the interior upholstry, but that is it.
Old 05-12-2013, 08:46 AM
You're doing it right. Will be interested in watching it come back to life. Stu
1949 Ford F5 Dually Rear Suspension Shake-N-Bake68 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-17-2014 07:14 PM
1949 F4 awjjim Georgia Chapter 12 06-11-2014 11:32 AM
Factory flatbed truck to truckbed? 1978fordmoneypit 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-06-2014 01:24 AM
1949 Ford F1 oscardgarza 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-02-2013 08:30 AM
Stakes for 1949 F5 Flatbed NDP 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-17-2011 05:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
