'95 F350 460 exhaust manifold gaskets
Old 05-11-2013, 05:38 PM
Cleanseeker's Avatar
Cleanseeker
Cleanseeker is offline
Hello all,
New to the site and I'm looking for input on what brand of exhaust manifold gaskets work best as well as tips for the replacement of them.
Any input is appreciated.
Thanks
John
Old 05-11-2013, 05:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Personally I am not a fan of them. NONE were on the engine from the factory, and I like to keep it that way.
If you have a leak, you have an issue. Either a cracked manifold or broken bolt(s)
Old 05-11-2013, 05:53 PM
Cleanseeker
Thanks for the response. They are leaking because the last set of gaskets installed are shot and have blown out in places. So should I remove the manifolds and reinstall with no gaskets and new hardware? They are leaking bad enough to cook the plug wires.
Thanks
John
Old 05-11-2013, 09:46 PM
Diesel_Brad
I would take the manifolds to a machine shop and have them decked. It will make them flat and true again, then install with NO gaskets and new bolts with hi temp antiseeze
F-250 WARHORSE
34
07-08-2021 04:06 PM
Sam's1967
04-30-2019 01:18 AM
bluesky636
04-21-2005 12:00 PM
bluesky636
11-28-2004 03:27 PM
fyrfytr
05-27-2002 11:22 PM
Quick Reply: '95 F350 460 exhaust manifold gaskets
