2001 f250 v10 tranny problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-11-2013, 03:03 PM
Spearman25 Spearman25 is offline
Spearman25 is starting off with a positive reputation.
Hey yall. My buddy brought me his 01 f250 it wont shift out of 1st then if it does it slams into second then the rest of the gears are fine. This was after he over heated the tranny last sunday in the mud while he was at work. He was low on fluid so i had him add some. I shift manually thru the gears it seems to work could this be a vacumm or a clugged filter
Old 05-11-2013, 03:43 PM
KenReb KenReb is offline
KenReb is starting off with a positive reputation.
Unhappy
Quote:
I am thinking a big NO, if he was low on fluid AND overheated. Not good!
Old 05-11-2013, 04:02 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I'm thinking he just blew $2,000.
Old 05-11-2013, 04:57 PM
No od now..... i think he screwed up the clutches
Old 05-11-2013, 05:23 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Quote:
Its transmission time.
Old 05-11-2013, 05:27 PM
Nope trade in time...
Old 05-11-2013, 05:33 PM
BlindLucky's Avatar
BlindLucky BlindLucky is offline
BlindLucky is starting off with a positive reputation.
Post manual automatic
I would drop the filter after running a flush mix thru it then change filter
hopefully this gets the torque converter too ( drain plug?)
If it doesn't work then your out the cost of clean fluid a filter and less time than it takes to change the trans!
gl
Old 05-11-2013, 06:36 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Fresh fluid can't fix damage that's been done. I agree with the consensus above, he likely needs a rebuild.
Old 05-11-2013, 07:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
gl
It won't work. It's just a waste of time and money. This one is finished.
Old 05-15-2013, 03:14 PM
well i have drivin it for a week when its cold it shifts kinda soft like normal but doesnt wanna come out of 1st. then when its warm about 10 miles it flashed and shifts kinda hard and makes a high pitched squealing noise. I am going to hook my new scan tool up what codes might pop up? i know the incorrect gear ratio code means new tranny lol but would there be a code for a clogged filter. he may have some water or something in it i may drain it and test.
Old 05-15-2013, 03:39 PM
A clogged filter won't set a code. If you have a clogged filter the transmission is toast. A gear ratio code does not necessarily mean a new transmission.
Here are some of the codes that may come up:
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear I Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stock On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stock Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
Old 05-18-2013, 08:41 AM
BlindLucky's Avatar
Exclamation
over heated the tranny I shift manually thru the gears it seems to work could this be a vacumm or a clugged filter
The path most taken doesn't always lead to the proper destination...
I'm no engineer, mechanic or smart...... Just LUCKY though blind!
Do the preliminary stuff first.... Code would be nice........ If the truck will shift MANUALLY and isn't slamming gears then you MIGHT get LUCKY....
Peace!
Flip Over Read Directions !
69 f-250 c6 shift linkage 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-15-2015 09:35 PM
E4OD streaming fluid now not shifting into any gear anelson2964 Clutch, Transmission, Differential, Axle & Transfer Case 6 06-19-2014 03:17 PM
89 f150 4x4 wont shift out of first gear tattman 1987 - 1996 F150 & Larger F-Series Trucks 10 09-04-2011 07:05 PM
tranny shifting hard and abs light is on dnlculver 1999 to 2016 Super Duty 3 09-12-2010 10:24 AM
Steering column/ignition/gear shift Locked. Mad.Scientist Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-26-2009 01:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
