Possible chevy 5.7 litre v8 install into 1960 f100 help - Ford Truck Enthusiasts Forums
Old 05-10-2013, 11:03 PM
SPEEDKING83 SPEEDKING83 is offline
SPEEDKING83 is starting off with a positive reputation.
Hey guys, great to be back on the site. Ive been busy working on my own truck, working mostly towards getting her road worthy. I do have a very serious question. I have a G20 5.7 litre V8 engine from and old chevy van along with the original trannie and i know its crazy, but im wondering if this transtiton to install the motor and trannie into the 1960 100. It originally came with the inline six with the original ford-o-matic trannie,which i still have, but the truck deserves a bit more oopmhm in her get up lol. But im worried about if this is a feasable attempt and do i need to replace the rear end which i suppose is the original as well in the truck, which is a short bed styleside. Im hoping that this is a good idea as im sending the engine in for an overhall and a total makeover anyway, but i want to know for sure if its possible and if so, what parts do i need to alter or change out in order to make this happen. Any help would be greatly appreciated you guys. Thanks again, God bless, and happy cruising. And as Stepehen King once said, this ones for the burg. Pittsburg that is, lol.
Old 05-10-2013, 11:42 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Your rear axle should be a Ford 9 inch, plenty good for the motor you are thinking of. Ratio wise it may not be perfect.
How "old" is that motor? Don't go through all the trouble of swap like this and install a worn out smog motor that barely makes 100 hp anymore....jmo
You can look at these on line and get some ideas about making your own mounts, or find a kit that's close.
Engine Mount Kits | Advance Adapters
Old 05-13-2013, 08:38 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Drag racers use the 9" for good reason; they're tough to break. As far as ratio, they're also the best way to go because you can get used center sections, a.k.a. pumpkins, with just about any gear ratio you want. And you don't have to hire a rear end specialist to swap 'em.
You may have some here who will razz ya for putting a GM motor in a Ford. I prefer to have same engine in like vehicles (Ford in Ford, Chevy in Chevy, etc.). But a small block Chebby will fit in anything. I know I caught a bit of flak for using a GM alt and ign. module on my 223.
Last edited by fabmandelux; 05-14-2013 at 08:51 PM. Reason: Removed cursing.......
Old 05-16-2013, 11:07 PM
economan economan is offline
economan is starting off with a positive reputation.
well here's a couple'a pieces of info that I hope will help ya out.
I did a 305 in mine outta an old parisienne pont. I had kickin around.
A company named "transdapt" makes the motor mount arm kit as far as the rear tranny mount I just used the original one outta the parisienne & drilled some new holes in it to match up to the frame width. used a mid 70's dodge d-100 truck rad cuz the rad hoses location on the orig. rad wouldn't work out. just have to narrow the opening in the rad support a bit, I just used I piece of sheetmetal to do this. also used a aftermkt. flexfan as I thought the orig. clutchfan stuck out a bit too far.
...The driveshaft ....well I just wandered around the wrecking yard with a measuring tape, til I came across one the right length, mine is a short box truck (well it was at the time, it's now got a panel body on it) found the shaft in back of a van with a whole raft of S-10 parts in it so I gotta assume its outta an old s-truck then just used adapter universal joint on the rear end, the front end plugged right into the splines on the trannie
shifting is looked after by an automatic column outta a 57 fairlaine just had to lengthen it a wee bit, 1/2 inch or so. (nothing looks worse than a modern column/steering wheel on any vintage vehicle, many of these columns & wheels were works of art on their own)
mine is the 700R4 4 speed auto. with 3:50 rear gears, works just dandy, with the economy cam & jetted down quadrajet carb & 235 75 15's truck gets around the 30 mpg highway. (tho you ain't likely to get that outta a 350.
Whilst you're at it you may as well upgrade to pwr. dual action brakes, I used a booster & master outta a 88ish dodge 150 this is practically a bolt on item, you only need to slot the truck's original master cyl holes a wee but,& on the one I used even the orig push rod was the right length there is a bit of hyd fitting adapting to get the br. lite switch to hook up to the brass brake block & of coars you gotta lengthen the wires down to the frame.
s'all I can think of for now, hope you can glean some info from it.
Mikie
near Ottawa Canada
57 merc 100 panel & 64 econoline p/u
Old 05-17-2013, 10:36 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
I used the CPP engine and transmission crossmembers and it worked pretty well. I had to modify a radiator from a 75 Dodge Pickup to get the inlet/outlet on the right sides. If you go with shorty headers or the Chevy rams horns you should be good. I have some Hedman headers in mine but they just happened to work, and I have no idea what part number they are, or how to find out.
I had a 292 in my '60 with a Fordo, and the 350/700R4 woke it up BIG TIME.
I'll follow that by saying the only reason I used that engine is because I had it and it was fairly new. If yours is nothing special or needs to be rebuilt, I'd suggest trying to find a 5.0 or 390, just because putting that Chevy in there won't help you if you ever want to sell it.
Estate Sale full of Fords! Aldercomm 1957 - 1960 F100 & Larger F-Series Trucks 9 12-08-2016 01:37 PM
New guy, Another project. mackyoudip 1957 - 1960 F100 & Larger F-Series Trucks 16 07-17-2016 12:13 AM
Did you Fummins ? Robert C. Bob Brown 1999 to 2016 Super Duty 2 04-05-2015 08:42 AM
Gearing for rear and font 1960 4x4 highway daily driver Caveman2851 1957 - 1960 F100 & Larger F-Series Trucks 13 08-08-2014 10:58 AM
Which battery for my new 1960 223 V6 F100? uknunn 1957 - 1960 F100 & Larger F-Series Trucks 19 11-29-2013 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
