Rear transmission seal.
Ok, so I get the idea to check the transfer case fluid level yesterday and backed out the top plug and almost took a hot oil bath. Dumped a quart or so on the floor before I overcame the shock and got the plug back in. I looked thru some old threads and read that the only way this could happen is if the rear seal in the tranny is blown. I've only ever added a pint or so of tranny fluid to it the 18 months I've owned it. I removed the plug again this morning and let it drain till no more came out and got another quart or so. Have not driven it much today but I'm going to keep a close eye on it to see if it's refilling.
Anyhow, is it difficult to change the rear seal?
on
The rear trans seal and the transfer case input shaft seal are one in the same. It is a double lipped spring loaded seal that seals from both sides. Remove the transfer case and replace that seal and you're good to go. I've been been contemplating changing mine out. Still looked good last time the trans was out. With 208k miles and no problems, I'm riding it out a bit longer. Maybe the synthetic fluid, I've been running on both sides, has made the difference.
jumbofordman
01-02-2018 10:42 PM
CountryBumkin
08-22-2014 12:42 PM
Nothing Special
05-05-2013 09:14 PM
