IDIT Performance Build - Ford Truck Enthusiasts Forums
Old 05-10-2013, 05:31 PM
xcite xcite is offline
xcite is starting off with a positive reputation.
This winter I decided to rebuild and build up my 94 F350 4x4, factory turbo, CC. I decided to build for the best balance of reliability and increased power. Below is a list of things done to the engine so far.
Block
Sleaved
Line Bored
Decked
Balance Rotating Assembly
Shaved pistons .005 out of Deck
Tri-coated Pistons
Dry Film Coated Bearings
Stage 1 Cam
Heads
New Valves- Ceramic coated faces and dry film coated stems
Performance Valve Springs
4 Angle Valve Job
Head Studs
Soon to have first set of Harland Sharp Custom Roller Rockers
Exhaust
All Castings Ceramic Coated
New Up Pipe Castings
Misc
Custom Intake
Custom Turbo in Factory Location, A3K
Powerstroke Intercooler
Heavy Duty Tranny Cooler
G code Injectors set to 2300 psi
Upgraded Fuel System, 180cc DB4 pump on order
Everything cleaned and repainted
Will update list as I finish adding new items.
Just a few teaser pictures.
Coatings
Pump and lines installed
Last edited by xcite; 05-15-2013 at 11:06 PM. Reason: Added Pictures and descriptions
Old 05-10-2013, 05:52 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4 86f250XLT-4x4 is offline
86f250XLT-4x4 is starting off with a positive reputation.
I think I'm in love lol
Old 05-10-2013, 05:56 PM
Fordidipower Fordidipower is offline
Fordidipower is starting off with a positive reputation.
I'm so turned on right now.....did I just say that?
Old 05-10-2013, 05:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
now that looks nice right there. what do you expect for power ratings?
Old 05-10-2013, 06:00 PM
Quote:
Thanks.
I am not going to say just quite yet but will let it out of the bag soon.
Old 05-10-2013, 06:07 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
dang ol, dang ol. that is one sexy IDI right there. man, can't wait to see what it does.
Is that the A3K? what are you doing for a fuel system?
Old 05-10-2013, 06:11 PM
A3K Yes. Will be told later.
Old 05-10-2013, 06:29 PM
I bet your a tester for the new db2 and your going for a solid 400 or more
Old 05-10-2013, 07:22 PM
Quote:
cool and cool!
Quote:
i hope he is going with a 180cc DB4 on this thing. it should be nuts with one of them on there.
Any H2o meth on this?
Old 05-10-2013, 07:24 PM
Yes I still have my water/meth kit on the truck.
Old 05-10-2013, 07:29 PM
ah, didn't even notice that in your sig.
Old 05-10-2013, 09:21 PM
racer30's Avatar
racer30 racer30 is offline
racer30 is starting off with a positive reputation.
Well That's a Fine looking Job Right there... I hope you are planning on taking a trip to the Dyno once you have it tuned... Bring a napkin for all the drooling IDI fans...
Old 05-10-2013, 09:47 PM
Might dyno it down the road sometime but not before it is properly broke in and no sooner then next winter, have a long busy summer of work for it to do first.
Old 05-10-2013, 11:29 PM
garrettsr5 garrettsr5 is offline
garrettsr5 is starting off with a positive reputation.
Wow I'm hard.
Old 05-11-2013, 12:02 AM
RacinNdrummin's Avatar
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is gaining momentum as a positive member of FTE.RacinNdrummin is gaining momentum as a positive member of FTE.
Looks good Allan...
Im sub'd to your thread for sure...
Intro and Aftermarket Parts Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-14-2016 03:43 PM
Big Orange got some new shoes! 1977 Highboy tlrtucker 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-15-2016 04:32 PM
transmission install issue (with mudding pictures! converter or pump grinding noise) kornfanjoe 6.0L Power Stroke Diesel 5 09-01-2014 04:31 PM
gauge cluster colour change!! kornfanjoe Excursion - King of SUVs 5 11-19-2013 09:08 AM
Mustang Week 2013 Pictures cobra_4 General Automotive Discussion 0 07-26-2013 09:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
