IDIT Performance Build
This winter I decided to rebuild and build up my 94 F350 4x4, factory turbo, CC. I decided to build for the best balance of reliability and increased power. Below is a list of things done to the engine so far.
Block
Sleaved
Line Bored
Decked
Balance Rotating Assembly
Shaved pistons .005 out of Deck
Tri-coated Pistons
Dry Film Coated Bearings
Stage 1 Cam
Heads
New Valves- Ceramic coated faces and dry film coated stems
Performance Valve Springs
4 Angle Valve Job
Head Studs
Soon to have first set of Harland Sharp Custom Roller Rockers
Exhaust
All Castings Ceramic Coated
New Up Pipe Castings
Misc
Custom Intake
Custom Turbo in Factory Location, A3K
Powerstroke Intercooler
Heavy Duty Tranny Cooler
G code Injectors set to 2300 psi
Upgraded Fuel System, 180cc DB4 pump on order
Everything cleaned and repainted
Will update list as I finish adding new items.
Just a few teaser pictures.
Coatings
Pump and lines installed
Block
Sleaved
Line Bored
Decked
Tri-coated Pistons
Stage 1 Cam
Heads
4 Angle Valve Job
Head Studs
Exhaust
Misc
Custom Intake
Coatings
Last edited by xcite; 05-15-2013 at 10:06 PM. Reason: Added Pictures and descriptions
cool and cool!
i hope he is going with a 180cc DB4 on this thing. it should be nuts with one of them on there.
Any H2o meth on this?
