'90 F350: weight of cab, frame, and such - Ford Truck Enthusiasts Forums
Old 05-09-2013, 07:30 PM
irhunter's Avatar
irhunter irhunter is offline
irhunter is starting off with a positive reputation.
Hi,
I am going to do a frame-off of my truck (in signature). This will be my first. As I think about how I will yank and move around the various components, it will help if I have an idea of weights.
Anyone have an educated guess of the weight of:
1. Stripped cab (no doors, glass, or seats)
2. Stripped frame
3. Bed
Thanks,
Roy
Old 05-09-2013, 07:43 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
A stripped CREW cab I would guess to be 400
Bed is 200
frame is 200-300
Old 05-10-2013, 08:51 AM
irhunter's Avatar
Thanks Brad. I was guessing somewhat more...but, have not much to base that on. The weights you suggest will make things go pretty easy.
Roy
Old 05-10-2013, 12:44 PM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
I'm currently doing the same thing but with an excab. It's still a heavy **** and a pain to move around myself. I've been using an engine hoist with straps to lift it and made a plywood and 2x4 platform on wheels to move it around. I would say 500lb (stripped except for glass) is not out of the question. I tried to rock it back so the rear window was on the ground to work on the underside. I'm fairly big and strong but could not do it, had to instead rock it forward from the back and still felt like 200-300lbs of effort.
As for the frame, I cut it in half and the back half and bed became a trailer, the front half (bare frame except for TTB still attached) hit the scrapyard scales at about 800lb. Draw your own conclusions.
Old 05-11-2013, 06:22 AM
Your frame estimate is HIGH
I have a bare reg cab long bed frame that I (by hand) took off of a trailer and put on a set of jack stands.
Old 05-11-2013, 09:46 AM
It's not an estimate, it's what the scale said and they're not in the business of over paying for scrap. The scale slip was 980lb and the only other thing in there was a IDI flywheel and two front fenders.
Old 05-11-2013, 04:49 PM
I can tell you right now a bare frame does not weight more than 600lbs. I would bet ALL my trucks on that
EDIT:
Just did some more searching. My original Number is low
A FACT that Lighting frame (a reg cab short bed frame,117") weighs 355lbs.
They are the same thickness as a 3/4 and 1/ton frame. That means it is 3.034lbs per inch. So a 168" frame(crewcab long box) weighs 509.74lbs
Old 05-13-2013, 01:13 PM
Good info, can't argue with that math. What's a D50 TTB weigh? That has to be 300lb right there? Then the springs must be 50lb a pair minimum.
Old 05-13-2013, 01:25 PM
irhunter's Avatar
Thanks guys.
Well, the stuff must weigh a lot...as I am estimating curb weight at 6,500 to 7k.
So, the thinking is:
8' bed, 200 pounds
Stripped crew cab, 400-500
Crew frame, 500 to 700
Damarble, you ran straps around the floor (through the door openings) and then picked the cab up, with an engine hoist, from the inside of the cab (at the center of the floor)?
Roy
Old 05-13-2013, 03:03 PM
Gettysburg150's Avatar
Gettysburg150 Gettysburg150 is offline
Gettysburg150 is gaining momentum as a positive member of FTE.Gettysburg150 is gaining momentum as a positive member of FTE.
Idk if it helps but the curb weight on mine is 7400 with 2 people in the cab and about 4 gallons of fuel
Old 05-13-2013, 03:14 PM
Quote:
Roy
Yep, had the doors off, ran straps to each corner inside and stuck the hoist arm inside. It's tricky to balance.
Old 05-13-2013, 06:44 PM
irhunter's Avatar
Thanks Gettysburg. Yes, good to know. That a Diesel, regular cab?
Thanks again Damarble, this is how I pictured it. I am sure with only one lift point it will be tippy.
Old 05-14-2013, 06:22 AM
Yes sir. Its the one in my sig. Reg cab, diesel, 4x4, 5 speed, dually. It has like a 163? wheelbase I believe so Idk if that makes a difference. Also the dump bed is aluminum. So its not 100% the same as everyone elses but its pretty similar.
Old 10-17-2013, 04:57 PM
irhunter's Avatar
Update on weights:
My GF and I just pulled my 8' bed. My guess is that it weighs somewhat over 200#. Maybe 250.
It is a handfull for two people. I would say, 4 people and it would be easy, and you could be gentle and precise.
Now to the cab.
Roy
Old 10-17-2013, 06:59 PM
Briansshop's Avatar
Briansshop Briansshop is offline
Briansshop has a good reputation on FTE.Briansshop has a good reputation on FTE.
My 7.3PS Crew Cab tips the scale at 7800lbs.
F250 Super Cab, Lond Bed frame weight? abosely 1987 - 1996 F150 & Larger F-Series Trucks 3 12-25-2015 01:34 PM
87' thru 96' frames same?? abosely 1987 - 1996 F150 & Larger F-Series Trucks 8 11-23-2015 06:45 AM
Question about supercab weight xcalbr2 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-23-2014 05:59 PM
1979 f350 regular cab weight fulltimehiboy 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-21-2013 04:30 AM
Trail Truck Dilema Mudman Offroad & 4x4 8 10-13-2007 03:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
