460 Falling flat a 2K RPM
I've got an 86 f250 with a 460. The PO put an Edlebrock performer intake and a newer Holley carb. I can't make out which Holley but its a 4bbl. When I got it, the distributor was off one tooth and the carb was all messed up. It was shooting flames from the tailpipe.
My buddy has fixed the distributor, reset the timing to 10 degrees and tuned the carb to set the idle properly. We found that a vacuum hose was missinfg to advance the spark and have replace that.
We're both scratching our heads on the next problem. The engine sounds good at idle and pulls strong up to 2000-2200 RPM but then it falls flat. My only guess is that the secondaries aren't kicking in but I'm no mechanic.
I'm leaning toward replacing the carb with an Edlebrock performer 600 or 750 cfm but don't know if that would help. I've read a lot of people ditch a Holley setup on the 460. Any thoughts or ideas would be great!
Vacuum or mechanical secondaries? You said you had a vacuum line missing to the advance canister, could you something else leaking vacuum keeping vacuum secondaries from working properly? It sounds like it's probably a fuel restriction to me.
I have an Edelbrock 1406 600 CFM carb on my 460. Vacuum secondaries, electric choke. It's just about dummy proof...
I didn't have a chance to work on it this weekend since its at my buddy's shop. I did do A lot of reading. I'm going to start by checking out the fuel sending unit with a fuel pressure gauge. If that checks out then I'll go under to see if the exhaust is a problem, but I think because its GVWR is 8600 that it was excluded from the Cat requirements. I'll probably replace the distributor cap regardless just to eliminate that.
Last on the list will be the carb. As I mentioned we have that tuned and it doesn't seem to have a problem with the power valve. Although I would prefer to change it to an Edlebrock 1406 or 1411.
One thing I did realize as I was reading is that the emissions "stuff" has been removed. I'm hoping that they knew how to do that properly or that could be a can of worms.
Hopefully you can get a good look at it soon. Good luck!
So I had a few minutes between rain storms to mess with it a little. Here's what I've learned
1. No cats so that's ruled out.
2. The carb is a Holley 80457-8 600cfm with electric choke on an Edlebrock Performer 460.
3. Emissions are all removed.
4. The distributor cap and plug wires are in good shape.
With base timing set to 10* and the carb tuned the motor stumbles and shakes still at 2K.
I'm going to get a timing light on it after the next storm to see what's happening with the timing at 2K. I have a feeling that its the ignition system. Just hoping the timing isn't the culpurate.
Well that's interesting. There should have been a line off of the air pump (which I guess is now gone) that goes to the back of the engine. I believe that it either needs to be hooked to the air pump or be plugged up. With that line just disconnected, it'll run rich. I know of one case where it even made a straight piped 460 throw flames about 3 feet ('86 like yours) if you were on the gas heavy then let off.
earl92
05-30-2015 03:41 AM
chumley360
06-14-2009 07:17 PM
oldmansimek
09-29-2005 06:12 AM
notyettoday
04-06-2005 07:11 AM
