'79 Brake Problem
'79 Brake Problem
I have a problem with my brakes that I can't seem to figure out. At first I had air in my lines so the pads weren't releasing pressure off the rotors when I released the brake pedal. When I went to bleed the brakes I stripped the bleeder screw off one of the calipers. Anyway I installed the new caliper, bled the brakes and I still have no brake pressure, I mean the pedal goes to the floor. I took it on a test run around the block, gave it some gas, hit the brakes and the back tires locked up so the back seems to be working fine. I really don't know much about brakes but I was thinking it might be the proportioning valve? What do yall think?
Received 3,105 Likes
on
Alright, well I think it's a bad master cylinder.
Is this the right one?
Fenco Reman/Master Cylinder (Brake System) (M1854) | 1979 Ford F150 1/2 ton P/U 4WD 8 Cylinders A 7.5L 4BL OHV | AutoZone.com
Don't go manual. Why would you do that!
Did you get ALL the air out of lines? When I swap a new empty caliper I leave bleeder screw open and pump about 5 times just to get the initial fill of brake fluid to fill caliper then proceed with bleeding.
Because Manual works much better for me... its not that big of a deal, just removed the booster, mounted the master cylinder to the firewall and cut down the rod and welded it up so it would let off pressure by about 3/8" and they work damn good, I can stop 38's just fine, and Power brake right on up better than i could before, Not to mention alot cleaner looking under the hood and the extra space...
Removing booster would be a downgrade.
I'm pretty sure your front brakes are full of air. I'd open bleeder on new caliper and pump a bunch of times getting the caliper filled.
