superduty...firestone airbag compressor location?
mount it ON THE FRAME. A family member had it mounted on the body up under neath. It was on the driver side, about mid cab. That thing got annoying when it kicked on. the harmonics would drone through the cab. I removed the whole system when he decided to lower the truck.
I think I have seen a mounting plate for accessories where its basically wide U-bolts that go around the frame to mount a flat piece of sheet metal. I don't know if it was custom made or manufactured but it looks really clean. If you want to get real custom, I would build an enclosure or have a plastic cover molded to keep it out of the elements.
Ted Bell
12-29-2010 04:23 PM
