gas tank filler neck - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 05-09-2013, 12:31 PM
62ESQ 62ESQ is offline
62ESQ is starting off with a positive reputation.
The other day my son and I decided to replace the exterior grommet on the filler neck of my 62 unibody. It was dry, cracked and hard as a rock. We of course didn;t think to use soapy water or something to help the grommet slide on but we got it on just fine with a little elbow grease. More his than mine. Ever since, I've noticed a strong smell of gas fumes in the cab. I'm thinking maybe we cracked the old rubber filler neck tube that attaches to the tank. I dont find any leaks anywhere from the tank but the filler neck hose is really dried out and hard as a rock. Has anyone experienced this? Is it just a matter of taking off the hose clamps on each end and replacing the ruber hose or am I missing something else? The sending unit appears to be attached to the tank just fine and I don't see any cracks along the fuel line.
Old 05-09-2013, 12:50 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 62ESQ View Post
The other day my son and I decided to replace the exterior grommet on the filler neck of my 62 unibody. It was dry, cracked and hard as a rock. We of course didn't think to use soapy water or something to help the grommet slide on but we got it on just fine with a little elbow grease.
Ever since, I've noticed a strong smell of gas fumes in the cab. I'm thinking maybe we cracked the old rubber filler neck hose that attaches to the tank. I don't find any leaks anywhere from the tank but the filler neck hose is really dried out and hard as a rock.
10's of 1,000 of people have!
Between the fuel tank and fuel filler tube is a neoprene rubber hose that clamps on. Hose hardens up/age cracks and/or clamps work loose, gas fumes emanate from hose.
1961/63 same as 1964/72:
Old 05-09-2013, 01:12 PM
Thanks! I knew that was kind of a dumb question. I'm sure thousands have had this happen on these 50 year old cars. From the drawing posted, it's part 9047. Dry and hard as a rock. Where can I get better drawings like this? Parts manual? The shop manual I bought is a little lacking.
Old 05-09-2013, 01:29 PM
From the drawing posted, it's basic part number 9047.
Basic part numbers shown in illustration section of parts catalog. Text section required to get complete part number.
1957/63 Ford Truck Parts Catalog available on a CD from hipoparts.com.
C1TB-9047-A (replaced 78-9047) .. Fuel Filler Hose / Reproduced
1961/77 F100/750 with in-cab fuel tank / 1937/48 Ford/Lincoln Zephyr & 1939/48 Mercury Passenger Cars.
Carpenter has it listed under 78-9047 for about 10 bucks.
Where in CA do you live? F100 Western Nationals Truck Show held 3rd week of June @ Canyon RV Park (aka gopher holes acres), part of Featherly Park complex, NE Anaheim.
Old 05-09-2013, 01:38 PM
Thanks Bill. That's what I need. A parts catalogue on CD so I can look at exloded drawings.
Front gas tank jephwoyo 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-11-2017 07:51 AM
Rear filler neck and hose... UGHHHHH smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 10-14-2015 01:31 PM
Front fuel tank issue and 'name that part' sloppyslim16 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 05-15-2015 05:46 PM
92 Ranger extended cab fuel tank removal is it hard? 1998Ranger25L153CID Ranger & B-Series 4 08-08-2014 10:54 AM
How To: Install New Fuel Filler Neck In Gas Ford Excursion ExploringNH Excursion - King of SUVs 1 01-21-2014 03:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
