2000 Alternator Size????
Your factory alternator should at idle have an out put of about
80 to 100 amps . Now these figures are granted that the entire
charging system is in good condition .From idle to self exciting
point about 2k rpm you may see as much as 150- 180 peak amps. If you have a group 65 battery in your ford keep the water level topped off with di or distilled water only. when you run a bear test or arbst test on it run the first test with no acceories on and you have an out put of about 80 to 100 amps . With acceories
on like a/c,radio,lights,etc is when you will see your peak numbers. good luck ford buddy.
turboted
turboted
