ok guys and gals if there is any. i am currently in the process of doing a diy d66 i aquired a 66mm turbo conversion kit from barder turbo services in pa i talked to the owner of the place for a good hour and half maybe more. i know it is expesive to but a turbo that is already set up but you can do it yourself for half the price. here are some pics of the set up the comp wheel is a billet wheel kinda like a larger version of the ww2 if you get my drift also has extended tips as well and very light compared to an normal d66 wheel also a little bit taller and also it comes with the 360 thrust bearing and everything needed to do a turbo rebuild
Ronnie, hows the new wheel working out for you ? Is that a stock 1.0 housing in your pic ? How is the power gain ? Any change in EGT ? Does it spool faster than stock ?
New stage 1's in the near future and it's time to rebuild my turbo. I am very interested in Barders' kit.
