diy d66 turbo - Page 3 - Ford Truck Enthusiasts Forums
diy d66 turbo
  #31
Old 08-07-2013, 10:11 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Yes you can get everything that you need as a kit from Barder turbo.
  #32
Old 08-08-2013, 05:53 AM
dizzyfingers03's Avatar
dizzyfingers03 dizzyfingers03 is offline
dizzyfingers03 is gaining momentum as a positive member of FTE.
Interesting.... I like things I can do myself
How does a D66 compare to an S366? Similar upgraded performance? Is one better at a particular application than another, say towing?
  #33
Old 08-08-2013, 07:26 AM
fordpride's Avatar
Their isn't a comparison. A S frame blows the d66 away
  #34
Old 08-08-2013, 11:56 AM
Jeepincj7's Avatar
Jeepincj7 Jeepincj7 is offline
Jeepincj7 is gaining momentum as a positive member of FTE.Jeepincj7 is gaining momentum as a positive member of FTE.
Quote:
I am curious which turbo you would go with in this setup:
An S366 or D66(building it myself)
Stage 1's
PHP Hydra chip
3" DP to 4" Diamond Eye
homemade bellowed up pipes
7.3L Intercooler
5spd manual w/ valair clutch rated at 400hp
6637
Stock fuel pump & bowl
T-500 HPOP.
Truck is a 2wd tow pig and daily driver.
I am looking for a quicker turbo response. Say from 1500rpms upwards. When does the S366 start to spool up in comparison to the D66?
I assume I would need E-fuel for the S366 as well, right.
  #35
Old 08-08-2013, 12:11 PM
fordpride's Avatar
The D66 isn't going to spool any faster then a stock turbo. It still used the stock exhaust side.
Both the d66 and s366 are gonna spool about the same time (s366 maybe a little faster) but the s366 is going to perform much better and keep egt's lower.
I'd use the s366
  #36
Old 08-08-2013, 12:19 PM
Jeepincj7's Avatar
I'd use the s366
If that is the case, then I would likely just stick with the stock turbo. I carry a spare just in case in the tool box anyway. I really don't have too much issue with EGTs now with the intercooler even close to 24K combined.
  #37
Old 08-08-2013, 05:22 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Hey Scotty, I'm curious to how you like the php hydra chip.
I ran that combo you mentioned with the stock turbo, except an automatic trans. It worked ok, but I was pushing some pretty high boost numbers (25 or so) on small hills towing so I upgraded to the S366. Now I get more boost (which this turbo can handle, the stocker wouldn't have lasted long imo).
  #38
Old 08-08-2013, 06:19 PM
Jeepincj7's Avatar
I usually try to keep the turbo at or under 20psi of boost, but its hit 36psi at WOT before a few times unloaded.
I like the chip for the most part, especially with the intercooler installed.
  #39
Old 08-09-2013, 01:43 AM
95350PS's Avatar
95350PS 95350PS is offline
95350PS is starting off with a positive reputation.
Got ahold of them and the whole kit shipped is 690. Sounds like a good route vs. The 1200 for a new d66
  #40
Old 08-31-2013, 09:07 AM
Slimline Slimline is offline
Slimline is starting off with a positive reputation.
Any updates on the performance op? My new stage 2's are eating my turbo alive.
  #41
Old 07-14-2014, 06:40 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Resurrection time. I'm curious to hear about how this has performed, any thoughts, comments, or regrets, regarding this system.
  #42
Old 07-14-2014, 09:26 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
I'm pretty sure he upgraded quite a bit since then lol
  #43
Old 07-14-2014, 10:57 PM
T_F_E's Avatar
T_F_E T_F_E is offline
T_F_E is gaining momentum as a positive member of FTE.T_F_E is gaining momentum as a positive member of FTE.
Still on my truck, works well. Stage 2's seem to work well with it.
  #44
Old 02-26-2016, 10:57 PM
nateairman's Avatar
nateairman nateairman is offline
nateairman is gaining momentum as a positive member of FTE.
Dredging this up after having a look at my turbo.
Does Barder still have a kit?
T_F_E are you still running it?
  #45
Old 02-27-2016, 01:43 AM
T_F_E's Avatar
As said before there is no comparison to a s frame turbo. If I were to do it again I would go with the t4 mount the first time!
Show me your fuel filler ideas The Outlaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 10-13-2016 12:21 PM
1 1/2 ton progress Steve Christensen 1947 and Older Ford Trucks 2 08-22-2016 04:20 AM
Cabs on Steve Christensen 1947 and Older Ford Trucks 23 05-08-2016 09:29 AM
Wiring cont Steve Christensen 1947 and Older Ford Trucks 1 03-28-2016 08:23 AM
Dump body Steve Christensen 1947 and Older Ford Trucks 1 07-26-2015 01:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
