diy d66 turbo
Old 06-04-2013, 10:31 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
Looks like a fun build!
Old 06-05-2013, 01:53 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Originally Posted by pjwoolw
Great find Rodney! Now I have plans for my spare turbo!
Thats a good idea! I have a spare turbo also, and i would like to learn how to rebuild one. I may try this out some day.
Old 06-05-2013, 09:00 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Question
Originally Posted by nomad221
Ronnie, hows the new wheel working out for you ? Is that a stock 1.0 housing in your pic ? How is the power gain ? Any change in EGT ? Does it spool faster than stock ?
New stage 1's in the near future and it's time to rebuild my turbo. I am very interested in Barders' kit.
Yes good find.
Same questions here
Old 08-01-2013, 04:28 PM
snknby123's Avatar
snknby123
snknby123 is offline
Results?
So how did the build go? Interested in your results good or bad. I just bought the 360 thrust bearing from Barder for my Van Turbo build. Surprised I don't see more info around here on the 360 thrust bearing.
Old 08-02-2013, 08:56 PM
T_F_E's Avatar
T_F_E
T_F_E is offline
Turbo is on my pickup now, seems to work good.
Old 08-03-2013, 07:02 AM
Talyn's Avatar
Talyn
Talyn is offline
Jim Sanders did something like this.
He used a different housing.
I'm not sure If I wanna do this or a 366 at the moment.
I'm pretty sure I'ma be putting a turbo in somewhere in the next 6 months.
Old 08-03-2013, 07:04 AM
Talyn's Avatar
Talyn
Talyn is offline
360 thrust bearing???????
You guys know that the Chinese rebuild kits fail due to poor quality and tolerances right?
Old 08-03-2013, 07:45 PM
fordpride's Avatar
fordpride
fordpride is offline
360* oiling. The stock one is a 180* oiling
Old 08-03-2013, 08:40 PM
snknby123's Avatar
snknby123
I picked up 360 Degree Thrust Bearing kit
Here's a couple pics of the 360 Degree thrust bearing I picked up from Barder Turbo http://www.barderturboservice.com. I don't work for them but I have heard good things from several people though. I believe the website says made in USA or UK. It appears to be of good quality. I have read where they can be steel or made of bronze. Bronze is supposed to allow for less heat transfer and the additional oiling will result in better reliability at higher boost levels.
Here is the Van Turbo I'm thinking of putting it in... https://www.ford-trucks.com/forums/1...l#post13401068
I haven't taken any measurements to compare to the stock yet
Stock:
360 Degree
Old 08-03-2013, 08:59 PM
snknby123's Avatar
snknby123
Old 08-03-2013, 09:25 PM
Triplespeed's Avatar
Triplespeed
Triplespeed is offline
I have a question on theses d66 upgraded turbo are these stock housing that have just been machined out to fit the bigger wheel and the outlet made bigger also
Old 08-05-2013, 06:22 PM
95350PS's Avatar
95350PS
95350PS is offline
Hate to bring this back alive but is this saying for 665 I can take my stocker and turn it into a d66 and it pull the same numbers as let's say a beans d66
  #28
Old 08-07-2013, 07:17 PM
tappit01's Avatar
tappit01
tappit01 is offline
bump................
  #29
Old 08-07-2013, 07:52 PM
fordpride's Avatar
fordpride
Yes. There is nothing special about a D66. It's a stock turbo with stock turbin wheel, turbin housing, 360* bearing, 66mm compressor wheel, 66mm housing, and a different backing plate.
  #30
Old 08-07-2013, 07:59 PM
tappit01's Avatar
tappit01
tappit01 is offline
thanks for the info mike. so the stuff i made bold in your reply is what a person would need to buy then. thanks again
Quick Reply: diy d66 turbo
