diy d66 turbo - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
diy d66 turbo
Old 06-04-2013, 11:31 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Looks like a fun build!
Old 06-05-2013, 02:53 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Quote:
Originally Posted by pjwoolw View Post
Great find Rodney! Now I have plans for my spare turbo!
Thats a good idea! I have a spare turbo also, and i would like to learn how to rebuild one. I may try this out some day.
Old 06-05-2013, 10:00 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question
Quote:
Originally Posted by nomad221 View Post
Ronnie, hows the new wheel working out for you ? Is that a stock 1.0 housing in your pic ? How is the power gain ? Any change in EGT ? Does it spool faster than stock ?
New stage 1's in the near future and it's time to rebuild my turbo. I am very interested in Barders' kit.
Yes good find.
Same questions here
Old 08-01-2013, 05:28 PM
snknby123's Avatar
snknby123 snknby123 is offline
snknby123 is gaining momentum as a positive member of FTE.snknby123 is gaining momentum as a positive member of FTE.
Results?
So how did the build go? Interested in your results good or bad. I just bought the 360 thrust bearing from Barder for my Van Turbo build. Surprised I don't see more info around here on the 360 thrust bearing.
Old 08-02-2013, 09:56 PM
T_F_E's Avatar
T_F_E T_F_E is offline
T_F_E is gaining momentum as a positive member of FTE.T_F_E is gaining momentum as a positive member of FTE.
Turbo is on my pickup now, seems to work good.
Old 08-03-2013, 08:02 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Jim Sanders did something like this.
He used a different housing.
I'm not sure If I wanna do this or a 366 at the moment.
I'm pretty sure I'ma be putting a turbo in somewhere in the next 6 months.
Old 08-03-2013, 08:04 AM
Talyn's Avatar
360 thrust bearing???????
You guys know that the Chinese rebuild kits fail due to poor quality and tolerances right?
Old 08-03-2013, 08:45 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
360* oiling. The stock one is a 180* oiling
Old 08-03-2013, 09:40 PM
snknby123's Avatar
I picked up 360 Degree Thrust Bearing kit
Here's a couple pics of the 360 Degree thrust bearing I picked up from Barder Turbo http://www.barderturboservice.com. I don't work for them but I have heard good things from several people though. I believe the website says made in USA or UK. It appears to be of good quality. I have read where they can be steel or made of bronze. Bronze is supposed to allow for less heat transfer and the additional oiling will result in better reliability at higher boost levels.
Here is the Van Turbo I'm thinking of putting it in... http://www.ford-trucks.com/forums/12...l#post13401068
I haven't taken any measurements to compare to the stock yet
Stock:
360 Degree
Old 08-03-2013, 09:59 PM
snknby123's Avatar
Old 08-03-2013, 10:25 PM
Triplespeed Triplespeed is offline
Triplespeed is starting off with a positive reputation.
I have a question on theses d66 upgraded turbo are these stock housing that have just been machined out to fit the bigger wheel and the outlet made bigger also
Old 08-05-2013, 07:22 PM
95350PS's Avatar
95350PS 95350PS is offline
95350PS is starting off with a positive reputation.
Hate to bring this back alive but is this saying for 665 I can take my stocker and turn it into a d66 and it pull the same numbers as let's say a beans d66
  #28
Old 08-07-2013, 08:17 PM
tappit01's Avatar
tappit01 tappit01 is offline
tappit01 has a good reputation on FTE.tappit01 has a good reputation on FTE.
Quote:
bump................
  #29
Old 08-07-2013, 08:52 PM
fordpride's Avatar
Yes. There is nothing special about a D66. It's a stock turbo with stock turbin wheel, turbin housing, 360* bearing, 66mm compressor wheel, 66mm housing, and a different backing plate.
  #30
Old 08-07-2013, 08:59 PM
tappit01's Avatar
Quote:
thanks for the info mike. so the stuff i made bold in your reply is what a person would need to buy then. thanks again
92-96 Lift Kit makeos Ford Truck Parts for Sale 0 11-14-2014 09:45 AM
Mounting a Saginaw box on a highboy co425 1973 - 1979 F-100 & Larger F-Series Trucks 19 09-22-2014 03:09 PM
R model battery box Steve Christensen 1947 and Older Ford Trucks 2 06-24-2014 05:07 AM
Pics of new rear fenders f1 gregstith 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-22-2013 12:57 PM
s366 installed pics rodneywar 1994.5 - 1997 7.3L Power Stroke Diesel 15 07-30-2013 05:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
