Fuel leak from carb
Old 05-08-2013, 03:39 PM
AlanMac's Avatar
AlanMac
AlanMac is offline
Fuel leak from carb
Hey guys, I have an '86 F250, 460 cu.in., automatic, 2WD.
Fuel is leaking from where fuel line enters carb. It attaches to what looks like the "vapor separator" mentioned in other posts. Is that what this is?
http://i437.photobucket.com/albums/qq93/mcclintick_2008/vsoncarb.jpg
Whoever put this on, it must be the wrong part cuz it just spins if I try to tighten it. Took it off and threads were wrapped in teflon tape. Threads on the part and carb don't look/feel stripped. Put back in to see how it fits without the tape and fit doesn't get snug until almost all the way in - too much side-to-side movement. Here it is removed ...
http://i437.photobucket.com/albums/qq93/mcclintick_2008/vs2.jpg
Should I try to replace this part, from Ford dealer, how would I identify it and the carburetor? And how about a temporary fix until the weekend?
Old 05-08-2013, 03:45 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
No one can see the pictures, it takes you to a sign in page.
Old 05-08-2013, 03:57 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
looks like a fuel inlet fitting with a filter to me. whats the holley list number on the carb , located on the air horn front ? That number will I.D. the carb. ,I don't think that inlet goes on that carb . I've never seen one like that and I have worked on holleys for over 40 years
Old 05-08-2013, 04:11 PM
AlanMac's Avatar
AlanMac
AlanMac is offline
List # is 50262-2
Old 05-08-2013, 04:16 PM
AlanMac's Avatar
AlanMac
AlanMac is offline
Sorry about the photos. Could be cuz I DON'T KNOW WHAT THE HECK I'M DOING. It's been a frustrating morning. Apparently hotstuff can see them though.
Old 05-08-2013, 04:26 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
Holley model 4180 , ford. The list number will get you the correct fuel inlet fitting you need
Old 05-08-2013, 04:43 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
That does look like a fuel filter. I am wondering if your carb is aftermarket, and should have the standard fitting on it that comes with holley's(has the coarse screen and looks like a big nut) and someone has tried to install a fuel filter with the wrong threads.
Should he be using the piece in this link? And then install a external fuel filter with hose clamps?
http://www.summitracing.com/parts/hly-26-26/overview/
Old 05-08-2013, 04:46 PM
85lebaront2
Originally Posted by AlanMac
List # is 50262-2
It is the fuel inlet filter. A good number to use is this one: E5HE-9510-ED, Holley list number 50260-3.
This is he carburetor number from my truck. What you probably have is a stripped float bowl where the filter screws in. You should be able to order a replacement from Holley.
Old 05-08-2013, 04:48 PM
85lebaront2
Dave, that is the filter design my Holley had on it.
Old 05-08-2013, 05:34 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
Now that looks right 85lebaron2, did that carb come off a 460 motor?
Old 05-08-2013, 05:49 PM
AlanMac's Avatar
AlanMac
AlanMac is offline
Guys, I really appreciate the help, but I'm getting a little confused. Maybe cuz I don't have much experience with this stuff.
85lebaront2, when you say "A good number to use is this one: E5HE-9510-ED, Holley list number 50260-3," I'm not sure what you are saying. I have the E5HE-9510-MC, 50262-2, which I suppose is model 4160, 450 CFM according to hotstuff ... so I should ask for the fuel inlet filter for that one, correct? And see if the threads in the float bowl are stripped when I screw it in. Or maybe you're saying I should order the filter that fits your size carb because the inlet for mine won't come with a filter and I would therefore have to attach a separate filter inline??? Sorry I'm not understanding.
Should I get the part from a Ford dealer or from Holley guys? And if the float bowl is stripped, then what? I guess I can leave that until I find out.
From the Holley website, for model 4150/4160:
http://i437.photobucket.com/albums/qq93/mcclintick_2008/Misc%202/inletfilter.jpg
Old 05-08-2013, 06:01 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
I was wrong to correct my error the 50262-2 is model 4180 1985 ford 7.5 motor , got my Holley book out .the 50260-3 is a model 4180 , 1985 ford 7.5 motor manual trans. By the way I have a fuel bowl if you need it .
Old 05-08-2013, 06:33 PM
85lebaront2
Gee, that's kind of strange. Mine was a 1986 F-350 7.5L with C6 transmission until I converted it to EFI and E4OD.
Yes, that is the carb off mine after I switched to EFI.
Old 05-08-2013, 06:52 PM
hotstuff's Avatar
hotstuff
hotstuff is offline
the carbs are made mo.s before the trucks so 1985 carb on a 1986 truck is not so strange
Old 05-08-2013, 08:41 PM
Franklin2's Avatar
Franklin2
Shouldn't any part store have this filter? I don't have time right now, but if I where you I would go to Autozone's site and plug in your truck, and see what comes up for fuel filter. They usually have pictures, and sometimes you can figure stuff out with some of these sites. RockAuto is another good one for research purposes, they even sometimes sell motorcraft, so if you did want the latest Ford part number you might find it there.
Quick Reply: Fuel leak from carb
