TRUCK STANCE JUST DOENT LOOKM RIGHT
Hey yall. im restoring my 83 F-100. im running into an issue with the truck stance. the back end on the passenger side is sitting a couple inches lower than the drivers side. ive looked at the leaf springs and they don't look broken but I also havnt taken them off and looked at them. should I just find some springs off a 3/4 ton and see what happens?
They don't have to be broken to sag, they could be just worn out. Also, breaks (or even cracks) might not be seen until the spring pack is pulled apart.
I believe 3/4 ton springs won't fit. You'll need a new set of F100 or F150 4x2 springs. 4x4 springs are an inch wider and also will not fit.
randallwdyck
05-12-2009 06:32 PM
TheTinian
12-06-2007 06:11 PM
Boss50
07-24-2004 05:43 PM
lilpig88
06-26-2003 05:27 PM
