Lights stuck on - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lights stuck on
Old 05-08-2013, 08:48 AM
Machplowboyny Machplowboyny is offline
Machplowboyny is starting off with a positive reputation.
Lights stuck on
So I was downloading a new tune from my SCT Livewire about 2 weeks ago in the McD's parking lot when it wiped my pcm clean. While messing with the truck the running lights came on, auto setting, and they won't go back off without disconnecting the battery negatives. I even pulled every relay while they were on and nothing. It's fine during the day but once the auto lights kick on the parking lights are locked on. If I take the key out even with the switch in the off position they will stay on and the chime dings like I left my lights on. While I was messing with it and hitting the brake the tbc fault was coming up. No trailer attached. Since I bought the truck, anytime the trailer was attached and I hit the brake I'd get trailer disconnected message so I figured it was in my trailer plug and it was back feeding. No dice. Truck is an 05 F 250 CCSB Lariat 6.0 4x4. I'm in NY but truck is from Texas. Extremely clean. Any ideas where to start? Thanks in advance guys.
Help! Truck Fault Causing 100% Braking of Trailer!!! Aufgeblassen Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 21 07-14-2014 06:39 PM
running light issues bleedin'blue Electrical Systems/Wiring 2 01-06-2012 11:04 PM
'99 7.3, Electrical issues JPdiesel 1999 to 2016 Super Duty 7 09-15-2011 11:11 AM
Fun electrical issues JPdiesel 1999 - 2003 7.3L Power Stroke Diesel 5 09-14-2011 08:01 AM
Tekonsha P3 installed, problems with trailer! freesoul Excursion - King of SUVs 3 09-30-2010 02:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
