1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2002 navigator rear a/c blows cold then warm
Old 05-07-2013, 11:17 PM
jeffrey5679's Avatar
jeffrey5679
jeffrey5679 is offline
I recently took my 02 navigator to the shop to get the a/c serviced because the rear air was not blowing cold. After service the front and back a/c worked great for a few hours then the rear a/c started to blow warm air. The front works great and will change from hot to cold when I change temp settings. The rear will change from hot to cold also but sometimes it will start to blow warm air instead of cold air. When the rear is blowing warm air I can change the temp setting to hot and it will get hot but when I change it to the cold temp it only reaches room temp air or slightly cool air. Anyone know why only the rear will sometimes not blow cold air.
Old 05-08-2013, 08:30 AM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
Sounds like it might be a blend door problem. Either the actuator or the door itself.
Old 05-08-2013, 09:29 AM
jeffrey5679
the rear heater still works perfectly and the temp will change from hot to room temp air or slightly cool. Would that still be the case if its the blend door? If so which blend door would it be?
Riceburnerfb1
21
06-28-2016 04:45 PM
Riceburnerfb1
06-25-2016 05:34 PM
OutlawNomad
04-08-2010 03:38 PM
01silvergt
04-25-2006 10:18 AM
DWL
01-16-2006 04:43 PM
Quick Reply: 2002 navigator rear a/c blows cold then warm
