2002 navigator rear a/c blows cold then warm - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-08-2013, 12:17 AM
jeffrey5679 jeffrey5679 is offline
jeffrey5679 is starting off with a positive reputation.
I recently took my 02 navigator to the shop to get the a/c serviced because the rear air was not blowing cold. After service the front and back a/c worked great for a few hours then the rear a/c started to blow warm air. The front works great and will change from hot to cold when I change temp settings. The rear will change from hot to cold also but sometimes it will start to blow warm air instead of cold air. When the rear is blowing warm air I can change the temp setting to hot and it will get hot but when I change it to the cold temp it only reaches room temp air or slightly cool air. Anyone know why only the rear will sometimes not blow cold air.
Old 05-08-2013, 09:30 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
Sounds like it might be a blend door problem. Either the actuator or the door itself.
Old 05-08-2013, 10:29 AM
the rear heater still works perfectly and the temp will change from hot to room temp air or slightly cool. Would that still be the case if its the blend door? If so which blend door would it be?
A/C diagnosis assistance needed 97ExpGuy 1997-2006 Expedition & Navigator 2 06-24-2014 08:01 PM
rear a/c doesnt blow cold air jdm5630 2007 - 2014 Expedition & Navigator 7 06-13-2014 12:20 PM
Rear A/C blowing warm and front blowing cold Pitcrw6 Excursion - King of SUVs 36 10-08-2013 10:32 PM
Another 2000 Ford Expedition with heater problems husky390 1997-2006 Expedition & Navigator 7 11-04-2012 01:14 PM
2004 6.0 A/C Issues Jtac80 6.0L Power Stroke Diesel 10 05-15-2012 05:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
