79 f350 jack it up Qs
#31
79 was years before I was born is my excuse...
......*Flip*
This guys getting lots of good info on his build.
#33
I thought A/O answered his question just fine with the first post...
#34
all this talk about D44 vs D60 made me go and check to make sure it had a D60 still under it sure enough it does... door tag for axle is 37 which means 3.54 gear ratio D60.just to be on safe side i decided to check the axle tag on pumpkin same under there- 9/16th bolts and tag read 3.54 and axle code was- 610023-2... How big of tires can a d60 handle comfortably?
#38
#39
it will be spending most of its time at pipeline near Crivitz WI, and a few mud racing events.
#43
that might just happen,do you usually go on the north or south end trails?Sadly i most likely won't be goin up there this year because of work and the truck isn't even close to finished
#45
it started out as being revived from sitting for 8 yrs
this was after replacing the grille and some paint. the bumper on front is from the previous owner he had a hitch of some sort on front which he used to pull/push hay wagons.
this is after i removed the rusted shackles and hangers
when i first got it the hanger was rusted out so previous owner had a chain to hold it in place
The flatbed had to be removed to gain access to working on the leafs and boards were rotted.
