Custom flash tune along with Ts Chip.
I know that you can flash the PCM - and then put a chip in since it overrides the settings.
I guess my (2 part) question is - when you use the 'STOCK Tune' setting on a Ts chip - is the tune on the chip, or is it just turning off the chip - and using the tune on the PCM itself?
And along those lines - is it possible to upload a flash tune (while in the 'stock' switch setting) to the PCM for use, so that I could use additional 'custom' tunes without having to re-flash the Ts chip?
I would not attempt uploading a tune to the PCM with any chip installed. That process is known for taking out chips and PCM's.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
