A/c mech. - Ford Truck Enthusiasts Forums
New Mexico Chapter Join Chapter, Leader: CelticDevilDog
A/c mech.
Old 05-07-2013, 03:54 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
A/c mech.
Anyone in ABQ doing A/C work on the side? I would like to flush, evacuate and refill my 134a systme. I don't want to leave it with one of the businesses.
Old 05-14-2013, 10:05 AM
CelticDevilDog's Avatar
CelticDevilDog CelticDevilDog is offline
New Mexico Chapter LDR
CelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputation
Can't say I know anyone but I'll keep my ears open.
Old 05-24-2013, 10:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I was surprised to learn that AutoZone has vacuum pumps and manifold gauges under their Loan-A-Tool program. If you know how to do it, that's a huge deal! Flushing is NOT recommended unless you know exactly what you're doing and have a machine that costs a fortune.
Old 05-31-2013, 05:46 PM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
38Chevy454 is starting off with a positive reputation.
Flushing is easy, just blow compressed air through to get flush out. Just about any solvent is OK, I have used mineral spirits, but you can buy specific flush aerosol cans. Turn compressor by hand. Let it all dry out good. Works best to have all the parts disassembled. Then assemble with new O-rings, and make sure to oil the O-rings, and then pull the vacuum for around 1 hour to get any moisture out. Then pull vacuum again, shut it off and see if it holds. If good, then put new oil in (assuming you flushed compressor). Pull vacuum again and then charge up using gages. The key is to pull good vacuum for the 1 hour so any residual moisture or solvent will evaporate and will be sucked out.
A/C max blows out defrost. mshargrave23 1999 - 2003 7.3L Power Stroke Diesel 12 09-15-2013 01:02 PM
a/c pressure firebug 1994.5 - 1997 7.3L Power Stroke Diesel 6 07-31-2011 09:51 PM
A/C and A/C cycling switch vent Ranger & B-Series 4 06-04-2010 01:51 PM
a/c beartracks 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-24-2002 12:05 AM
I NEED A/C!!!???? Ferrite Cooling, Heating, Ventilation & A/C 1 05-26-2002 10:58 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
