94 F250 Fuel Delivery Question
Hello all!
So I've searched to the point of exasperation and I have found nothing on this topic. There is a FPR on the outlet side of the fuel rail, that is there for obvious reasons. What in the world (?!) is the fuel regulator appearing thing on the INLET line. It is not vacuum controlled but looks like an FPR. Is it to keep flow speed down or something? I cannot find mention of this regulator anywhere and I don't understand why it needs to be there?
Thanks!!
Thanks!!
Alright, so after standing on my head with a mirror tucked in my right arm, flashlight in my mouth and lots of grunting, I was able to get some degree of a part number off of it. Turns out it wasn't the right number, but it did solve the mystery... sort-of.
It's a fuel-pulse damper. Supposedly its to reduce the pulses from the fuel pump to prevent pressure surge.
I wonder if it was a '93/'94 thing? My truck is an April 1994 build.
And check this out!! It has a picture too, but I don't know how to post pictures yet.
TSB 93-01-16 Fuel Pulse Damper 4.9L
TSB 93-13-09 Fuel Pulse Damper 5.8L
Publication Date: JANUARY 5, 1993
LIGHT TRUCK: 1992-93 BRONCO, F-150-350 SERIES
ISSUE: A fuel system "knocking" noise may be heard. The noise is caused by fuel injector pulsations that are transmitted through the fuel lines.
ACTION: Install a new front fuel line assembly with a pulse damper. Refer to the following procedure for service details.
SERVICE PROCEDURE
1. Relieve the fuel system pressure. Refer to the 1992 F-150-350, Bronco Service Manual, Page 10-01A-26, for fuel system pressure relief procedure.
2. Remove the existing front frame to engine fuel line assembly. Refer to Figures 1 and 3 for fuel line disconnecting procedures on each end.
3. If any material was installed to isolate the "knocking" noise previously, remove it.
4. Install the new front fuel line assembly (F3TZ-9J338-G or F3TZ-9J338-H) with the pulse damper. Refer to Figures 2 and 3 for installation procedure.
5. Check the system to be sure there are no leaks.
PART NUMBER PART NAME
F3TZ-9J338-G 4.9L Front Fuel Line Assembly (Bronco And Regular Cab F-Series)
F3TZ-9J338-H 4.9L Front Fuel Line Assembly (Super Cab F-Series)
F3TZ-9J338-J 5.8L Front Fuel Line Assy. (F-Series, Regular Cab And Bronco)
F3TZ-9J338-K 5.8L Front Fuel Line Assembly (F-Series Super Cab)
SUPERSEDES: 92-24-11
WARRANTY STATUS: Eligible Under Bumper To Bumper Warranty Coverage And 1992 And Later Model Emissions Warranty
OPERATION DESCRIPTION TIME
930116A Replace 4.9L Front Fuel Line 0.4 Hr.
SERVICE PROCEDURE
The following users liked this post:
Ok so here's my theory on the whole thing. Since the pre-'96 rigs were bank fire SD trucks they had 4 injectors fire at a time. This probably made a big enough drop in the fuel rail to cause pressure surges that could be heard in the line. Once they went to sequential fire with MAF and/or OBD-II there was only 1 injector firing at a time which is less fuel rail trauma aka pressure drop...
Does that sound reasonable?
