Dana 50 swap and a whole lot of Cussin
#91
Sheesh. What are the odds? I'm glad you got it all figured out. I guess I would have thought that the axle joints would have let the shaft straighten out since there isn't a carrier bearing or anything in the middle. I guess that's not the case. At any rate, I'm glad you got it figured out!
Give kawamatt22 a break William, he is only trying to help. And if you go back and look at your second video, at about 54 seconds in I can see wxactly what he is referring to. It must be an optical illusion or something though because you guys have assured us that it is seated completely tight into the axle beam. I can see what he was talking about too and I'm not sure what it is either.
#92
Thought the video was going to be about a D60 swap and all of the pages would be full of informative info so I subscribed late last night and planned on reading all of it this morning. This morning I watched in horror as the D50 was "installed"! I tried to play it in reverse to undo some of the trauma...it didn't work. And most of the pages are about iced tea, suspenders, a dog and a missus that I apparently didn't see.
But still a very enjoyable read and I appreciate your tenacity in finding the problem!
Seems an odd way that the beam was bent...any idea how it got that way and did your portapower rig bend it back?
#93
on
1 Post
#94
You still wouldnt hear anything.....
Youd actually have to use the differential which wouldnt work in the first place cause a hub is missing which would just destroy the spider gears.
Differentials dont turn unless you put it in 4wd or if you dont know how to properly service and install manual lockouts.
You need to take a chill pill. At least Bill got it figured out.
#99
I made a mistake saying he should have heard something (happens), but I just saw no way it would be in the diff.
#100
I don't make long lengthy wordy posts while typing from my phone, so they come out a bit .. more harsh.
#101
#102
At least Bill was able to narrow down the problem.
#103
My point was that if you can remove the axle and everything assembles like it should, no binding no mis-alignment of anything, you have narrowed down the problem to something on the truck. If with with the axle removed from the truck it still wouldn't bolt together correctly, you know the problem is with the axle assembly itself.
That was what we came up with.
I'm just glad he had a porta power to test the theory.
The actual axle bending like that from being bolted up to the springs is just absurd and not really possible.
Cody93idi
04-15-2013 11:28 AM
blucollar4xford
04-22-2010 08:47 PM
ghunt
10-24-2007 09:56 AM
