Does anyone have any ideas for shocks on the front of my 1959 f100
it has a 1979 d44 front axle. the steering arm is coming from the back of the axle because its a 59 but the arm goes over the shock mount from the 79
Welcome to FTE! There are several guys around here with the 4x4's. My solution would be to cut the shock mount off and put it where it needs to be for you mongrol truck!
that is what i thought i would have to do. it is going to be a tight fit.
will have to get help im not very good at welding. this is my first truck hoping to drive soon here is a picture maybe you guys could suggest what color i should get it painted
