oil or fuel in water?
Old 05-06-2013, 10:18 AM
Phoppe's Avatar
Phoppe
Phoppe is offline
2001 F250 7.3L. Got something in water. Not real sure where to start truck runs good but with pressure cap on water bottle it blows out white sludge. Water does not really smell like fuel nor is it dirty like oil. Been told the oil cooler has been replaced not sure that is true though. Keeping open mind there. Can anyone help me identify the contminant for sure and maybe guide me toward the fix. Any and all help would be apprecijated. Been told oil cooler, injector cups, head gaskets. Whatever it is it seems to be adding pressure to coolant bottle
Old 05-06-2013, 10:23 AM
grec-o-face's Avatar
grec-o-face
grec-o-face is offline
If it doesn't smell like fuel, the next thing I'd check is the oil dipstick. Check for coolant contamination. The oil cooler (o-rings/gaskets) may have failed - cross contaminating the oil & coolant.
Old 05-06-2013, 01:04 PM
Phoppe's Avatar
Phoppe
Phoppe is offline
Oil doesnt appear to have water in it. The truck has been sitting a few.days now so either fuel .or oil should be floating on water now. It should be more concentrated and hopefully ill get a better idea by smell and color. Will look again tonight
Old 05-06-2013, 01:14 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
Justin@DP-Tuner is offline
PREMIUM SPONSOR
When you say it blows out white sludge, do you mean there is white residue on the cab/overflow tank?
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old 05-06-2013, 01:18 PM
Phoppe's Avatar
Phoppe
Phoppe is offline
no with truck running pressure builds in coolant tank. Enough so it blows around edges of pressure cap. It is a whitish creamy colored sludge. Its not a dried on residue. Can stand there and watch it spew out
Old 05-06-2013, 01:23 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Gotcha. Anyway you could post a picture of this?
__________________
Justin
www.dp-tuner.com
Old 05-06-2013, 02:29 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
If it looks like this it is probably fuel.
Oil is hard to mistake, it's black. I made the mistake when buying my latest 7.3 of thinking it was oil, no big deal, I can fix the oil cooler. Well it wasn't dark brown/black, it was milky "yellow" (white and green makes yellow) on top of the coolant in the bottle. That's fuel.
If you still can't decide, you can always pull a sample and send it to black stone (site sponsor, top of the page) for a coolant analysis. They can tell you what's up.
Send us a pic if you can, maybe we can help get you fixed up.
Old 05-06-2013, 03:24 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
If it's fuel you can smell it.
Old 05-06-2013, 08:02 PM
Phoppe's Avatar
Phoppe
Phoppe is offline
Think were getting somewhere its about 3 inches of cream in coolant nothing dark so sounds like fuel guy told me bus friend put new oil cooler and it looks new. So where do i go next gonna post a pic shortly
Old 05-06-2013, 08:31 PM
Phoppe's Avatar
Phoppe
Phoppe is offline
Got pics trying to figure how to post em
Old 05-06-2013, 09:03 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Well if it's confirmed fuel, you'll have to test the injector cups. Look up a thread called "stinky's stick up" and you'll find out all you need to know about that and more.
Here's some reading as well. http://www.riffraffdiesel.com/mm5/RE...eplacement.pdf
http://www.riffraffdiesel.com/mm5/RE...structions.pdf
Edit: you can pressure test the coolant system prior to removing the cups, but the injectors will have to be out of the way.
Old 05-06-2013, 09:05 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
To post pics you need to use a photo sharing sight such as photobucket, and paste the direct link into [IMG] "direct link" [/IMG] (or click the yellow box with mountains in it and paste the link there.
Zack12
13
02-02-2023 11:12 AM
toyotaguy
09-26-2012 11:30 PM
moyreyes74
03-31-2010 11:33 AM
rodolan
12-08-2009 05:30 PM
PowerstrokeJunkie
87
08-05-2008 12:21 AM
Quick Reply: oil or fuel in water?
