1969 f250 camper special - Ford Truck Enthusiasts Forums
Old 05-06-2013, 07:48 AM
flamebringer69 flamebringer69 is offline
flamebringer69 is starting off with a positive reputation.
Having a hard time figuring out why the truck clunks when trying to steer. The guys say it the tie rods.king pins. I am also having trouble finding the outer tie rods looked on lmc and they show the part that I need tie rod I think. But they don't seem to have. Really need help and advice. The chiltons I have been loaned has little info. On a tight budget. Thanks from this lass
Old 05-06-2013, 10:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1969 F250 Camper Special
Quote:
Originally Posted by flamebringer69 View Post
Having a hard time figuring out why the truck clunks when trying to steer. The guys say it the tie rods, king pins. I am also having trouble finding the outer tie rods looked on lmc and they show the part that I need tie rod I think. But they don't seem to have.
Welcome to FTE
Camper Special makes no difference. Draglink, tie rods same: 1965/70 F100/250 2WD, 1971 F100/250 2WD before serial number M00,001.
These parts are available from a local NAPA auto parts store, so there's no need to buy from a repro parts seller, then pay shipping charges.
3304 is draglink, 3A130 is tie rod end, 3A131 is tie rod.
Old 05-06-2013, 11:32 AM
Thanks so much that really helps me.
Old 05-06-2013, 11:41 AM
Also did u get that build sheet of the internet? If so what site. She's a complete restore so I will be needing others
Old 05-06-2013, 02:14 PM
Also did u get that build sheet off the internet?
It's not a build sheet, it's a parts catalog illustration, it didn't come from any internet site.
1964/72 Ford Truck Parts Catalog available on a CD from hipoparts.com.
Old dog learned new tricks: I began posting parts catalog pics/text circa 4/15/2013, because next to no one else was doing same, especially in this forum.
Also acquired a 'magic wand' scanner, so now can scan/post pics/text from sources (including microfiche parts catalogs) not on CD's.
See album pics, taken by ctubutis, moderator of 1980/86 forum, who was here 4/3-4/20 and taught old dog new tricks.
Old 05-06-2013, 02:23 PM
Thanks I shall go there and get it then. U have been very helpful. I was not able to grab the attachment on my phone. But will be at my hone comp later today and I can print it from there. Once again thanks
Old 05-08-2013, 07:31 PM
flyboy2610's Avatar
flyboy2610 flyboy2610 is offline
flyboy2610 is gaining momentum as a positive member of FTE.
I hope I don't get in trouble for posting this here, but this is how I did mine:
The FORDification.com Forums • View topic - Frodo, the '69 F250 CS
Old 05-08-2013, 09:38 PM
70-360fe 70-360fe is offline
70-360fe is starting off with a positive reputation.
Might want to check the radial arm bushing also.
Old 05-09-2013, 12:19 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
The steering/suspension system has lots of parts that, if worn, can clunk, groan, and make all sorts of odd sounds.
But have you even crawled underneath the rig to do a visual inspection? What about rocking the truck to and fro to determine if you can see or hear any free play? What about jacking up one corner and rocking the wheels top and bottom and side to side? What about having someone turn the wheel while observing different joints to see if any parts do not move in unison when they are supposed to? Have some skin in the game.
Do not tell us that posting on FTE was your first step. Your troubleshooting method, skills of deductive reasoning, and use of that tool between your ears is required if you're gonna own one of these rigs..... And remember, there is no OBDII port to rescue your azz!!!
Old 05-09-2013, 09:48 AM
Wow that was like really mean. I have a better word for u but a lady should never use such words in such a public setting. Yes I did those thing first. I was getting 3 differant opions from the guys that I know. And before I went to buy to many parts I wanted restores point of views. I have never done this kind of extent of work. Just the basics. And the manual I have was no real help. ALL of it looks bad and no it dosent turn at all . I was not able to lift her yet.
Old 05-09-2013, 11:12 AM
HIO Silver's Avatar
Then tell us that you did those things first. We're not clairvoyant. Go about fixing your truck like a mechanic. .. 'not by throwing parts and money at it.
Mean? Ha! You'll need thicker skin and playing the gender politics in a "in a public setting" won't work.
Old 05-09-2013, 11:22 AM
Tim Hodgson's Avatar
Tim Hodgson Tim Hodgson is offline
Tim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to behold
I was getting 3 different opinions from the guys that I know. And before I went to buy to[o] many parts I wanted [other] point of views. I have never done this kind of extent of work. Just the basics. And the manual I have was no real help. ALL of it looks bad and no it doesn't turn at all. I was not able to lift her yet.
You're doing great kiddo. (Sorry for the kiddo, I can't help it at my age.) My moniker on FTE is "Learning slowly..." and sometimes I wonder about the first part.) But IMO, some of the most curt members are the most informative and really the most helpful once you get over your hurt feelings and can really focus on the advice that was given. Really, the most rude response, is no response at all.
So, when someone calls you a dummy or words to that effect, just pick yourself off the floor and get back at it with a renewed vengeance. Your best response is to take his/their advice, do the suggested work/inspection, post the results (with pictures if possible) and ask for (his/our) reply on what to do next. Make him/us put up or shut up.
One of the best slogans on this forum is F350-6's “Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers He doesn't usually have the time of day for me or my posts, but his knowledge and experience is golden when given.
Just keep gaining experience and posting your questions, your results and pictures, and all of these FTE members (even the ones that may first appear to be "mean") will have your back.
Old 05-09-2013, 01:21 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
I'm not part of the truck forum here since I have a much better bronco, all I can advise is that is someone is "mean" on here, laugh it off and keep going. There is a saying "an internet fight is like the special Olympics, in the end we are still retarded." It's a little rough and some think it's mean but it's true no?
Anyways, the other point is, these guys are old... No beating around the bush, and they have delt with a lot of younger people coming on here and just posting ***** nilly before searching the site and before trying to troubleshoot their problems. It gets kind of tiring having to tell people the same thing over and over, and I think that contributes to their "mean" responses.
Just take it with a grain of salt and look at the information given instead of the insult.
Old 05-09-2013, 01:39 PM
Quote:
Originally Posted by Tim Hodgson View Post
One of the best slogans on this forum is F350-6's “Good judgment comes from experience, and a lot of that comes from bad judgment.” -Will Rogers
"The best way to make an educated man stupid, is to take him off the subjects he's educated in." -Will Rogers
Tie Rod problems Kalahari south afric 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-22-2015 10:03 PM
Tie Rod Ends Or Not?? mtnxtreme800 6.0L Power Stroke Diesel 2 08-14-2012 08:00 PM
2006 F250 passenger side outside tie rod end 6.0L CAM 1999 to 2016 Super Duty 1 05-06-2012 11:22 PM
Tie Rods? fordnurse 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-19-2011 08:49 PM
103 bucks?? 88grandmarquis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-26-2003 11:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
