Navigator Spark Plugs - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-05-2013, 10:04 PM
gcburkett gcburkett is offline
gcburkett is starting off with a positive reputation.
I spent a couple hours today working on changing spark plugs in my 2004 Lincoln Navigator. I took a short at number #8 but could not disconnect the connect from the coil. Whoever decided to run the EGR tube over the number #8 coil should have to change Navigator spark plug for a living. The coil connector seem to break. I broken one but it seem two of them were already broke from the last spark plug change done by the dealer. The #8 connector seems to have the tab broken as well but I could not get the connector off the coil. Has anyone have problems with the connection removal on a coil?
Old 05-06-2013, 03:54 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
I had trouble with that one too and for the same reason, the EGR tube. I ended up using a pry bar to move the tube just enough to be out of my way.
Old 05-06-2013, 10:16 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
I always disconnect the wiring connector before loosening the coil pak, otherwise you need two hands back in there. Impossible.
All done by feel.
I had to loosen the fuel rail to access the #8 (drivers side) back plug. Once slightly removed, it can come out similar to the #4 plug.
Not an easy task.
Old 05-06-2013, 11:12 AM
Quote:
Always? Sheesh I sure hope you don't have to R&R it that often.
trouble with my 98 navigator steve olden 1997-2006 Expedition & Navigator 8 06-14-2014 10:55 PM
Misfire Error Codes & Check Engine Light benny8777 1997 - 2003 F150 6 04-30-2013 10:01 PM
no start condition (scope graph) maro0078 1987 - 1996 F150 & Larger F-Series Trucks 25 02-27-2012 03:17 PM
Low Ignition Spark - 1999 v10 - f250SD maxexn 1999 to 2016 Super Duty 18 02-19-2012 06:08 PM
Does your 32V DOHC Navigator have a rough idle/miss? Look here! ****DUW**** wchain 1997-2006 Expedition & Navigator 2 06-12-2007 03:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
